Quick Attach Handle Broke...replacement?
   / Quick Attach Handle Broke...replacement? #1
buyerjohn
Berkshires, MA
DK45s with cab
I snapped the handle/lever (at the attachment point) that opens and closes the 2 engagement pins...it looks like it may just bolt onto the pivot point but i'm not sure...anybody have suggestions on where to purchase a replacement?
I was using a cheater bar and obviously pushed too hard :(
thanks, John.
   / Quick Attach Handle Broke...replacement? #2
Who made the QA? Kioti or was it aftermarket?
I'm guessing you will need to go to the original manufacture of the QA to get parts.
I know I did when I did the same thing to mine. 5' cheater bar won over the QA.
Wedge
I'll need to check the plate...I think it's probably aftermarket (who makes them? ...does the handle typically just bolt on?
thanks
   / Quick Attach Handle Broke...replacement? #5
1) Weld it back together.
2) You should never need to use a cheater bar to close these things. If it doesn't close with hand pressure then something is not lined up properly. The Kioti quick attach is narrower than many others and it is possible to line up an implement off center so that the holes don't match up with the pins. While you have the welder out put in a spacer to prevent the implement from being off center.
I have a kioti QA and ordered a replacement handle for $30 from Rick Wallace..
Margaritaville Decorative Sign (A55758)
Margaritaville...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2016 KOMATSU D65PX-18 BULL DOZER (A55745)
2016 KOMATSU...
Adams 16T Tender Body (A55301)
Adams 16T Tender...
2022 Bobcat T66 (A53314)
2022 Bobcat T66...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox XHD-78HF...
