Kubota B6100 4x4 with new threads and shoes
/ Kubota B6100 4x4 with new threads and shoes #1
smokinhart
Manhattan, Kansas
B6100DT Kubota
Just about done and ready to mount the loader on the new refurb B6100:thumbsup::cool::thumbsup:
Before
[/IMG]
After
[/IMG]
Been a fun and challenging build.
/ Kubota B6100 4x4 with new threads and shoes #3
Very nicely done....B6100 now looks like mid 90 B7100.
/ Kubota B6100 4x4 with new threads and shoes #5
She looks pretty and the new shoes make her look sleek. Now I feel like I need to do some cleanup on mine. Although I did spend a bunch on adding power steering. :)
/ Kubota B6100 4x4 with new threads and shoes #6
I just checked out the post at the other site. You put in some hours on this tractor. Curious, how do you plan to power the loader? Mine is factory and uses the pump on the motor.
/ Kubota B6100 4x4 with new threads and shoes #7
Thats one good lookin tractor.
I have a Cessna pump on the front PTO for one circuit of the loader. I also have outboard connections from the factory Hydraulic pump on the port side of the tractor. 4 gallon per minute each outlet. Still do not know which I'll use!:confused2:
/ Kubota B6100 4x4 with new threads and shoes #10
Personally I think I would use your aux pump for the loader, I also have a rear blade and I am forever switching knobs and levers going from Loader to 3PTH blade.
KubotainNH Your set up is the same block I have for the factory port. David, . . . . I think you have the switch under the seat?! That would be a pain switching back and fort. I have both so I would be able to use the block on the port like Kubotain does and still have the aux pump dedicated to steering. The loader dual valve is PB with a output return as well. Then if I ever build a grapple fork I can use the under seat valve to operate that.
Thanks for the thought process guys!
/ Kubota B6100 4x4 with new threads and shoes #12
I never have to touch that knob. The 3 point hitch is in line after my FEL. Works like a champ.
/ Kubota B6100 4x4 with new threads and shoes #13
Hi Smokinhart. Would you be able to provide information on what you are running for wheels and tires on your B6100? I have the same model machine and would love to bolt on the same wheel and tire combo as my turf tires aren't cutting and I don't want to put on ag tires. Any info you could provide would be much appreciated.
/ Kubota B6100 4x4 with new threads and shoes #14
After
[/IMG]
That thing looks like a beast. Job well done.
/ Kubota B6100 4x4 with new threads and shoes #15
Thats a nice tractor,job well done:thumbsup:
/ Kubota B6100 4x4 with new threads and shoes #16
Awesome job on the restoration! That makes me want to spend more time with my b7100. What loader are you putting on it?
/ Kubota B6100 4x4 with new threads and shoes #17
I had a B6100 years ago. That's what sold me on Kubota. Those things are tanks! Nice job.
Thanks for the kudos.
I put an ARK 515 loader on it after those pictures were taken several years ago. 78" lift 42" bucket and front mounted crankshaft pump. New three spool valve . Works well ... Even built a belly hydraulic reserve tank in the frame. I'll post some current pics soon. I don't use the tractor much and even considered selling it this spring. If I decide to let it go I'll post on the appropriate board here to let y'all know ...
10 x16.5 skid loader tires on back and 6x10 loader tires up front. 6 ply are tough to mount on these rims! Kept the gear ratio within 2% if I remember to avoid drive shaft wrap differences.
/ Kubota B6100 4x4 with new threads and shoes #20
Welcome back smokinhart. You did a great job on that tractor. And I'll ask for SilverLakeFab, what wheels did you mount the tires on?
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2007 PETERBILT 387 QUAD AXLE DUMP TRUCK (A59904)
2007 PETERBILT 387...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
Unused 2024 Ray Tree RMSC78 Hydraulic Soil Conditioner Skid Steer Attachment (A59228)
Unused 2024 Ray...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
