ampa
Gold Member
- Joined
- Feb 9, 2009
- Messages
- 450
Thanks once again guys.....I'm learning lots about electrical.....one thing thats hard to take in....is...different brands of 110 volts....are they all basicaly the same....or do some of these wire feed welders draw less than than my Lincoln welder ?.....the queston put forth....are all extention cords solid wire or stranded ? to the question (stranded/solid.... they are all stranded to my knowlage.....if not the contractors with their beast of generators.....be buyin' extention cables every other day...(I'll class them as cables and not extention cords)......maybe a contractors heavy duty extention/cable would serve my needs.....I could get away with 50' because of the fused panel bein' at the front part of this duplex house we rent.....I may have to change the end male plug on the welder or use an adapter....because of the different male an female electrical plug above 15 amps.....someone mentioned going to an RV supply to get a heavy duty extention cord/cable....but I'm afraid of running 230 through my Lincoln.....The panel in this house has two 15 amp breakers not even hooked up to anything....I gather these are just spares in case a breaker goes bad....I'm not a electrician....it seems these breakers just pop in and out very easy....now the ones that are 30 amp black in color 2x15 as one tied together breaker making it 30 amps.....How are these breakers wireed together for say 30 amps without getting 230 volts to an dedicated single 110 30 amp receptical ?....it don't seem like rocket science to me.....but I'd be afraid of grounding positive to the negitive....that would make a big bang ....wouldn't it..!?.....lol....okay guys I'm gettin' closer to solving this breaker problem....keep the much needed information coming my way....I may not need my friend electrician to come down and wire this up....makin' it a DIY.....once again...a... big thanks to all you guys.....take care....Ampa...: and still...confused2:....somewhat...........
