BX 2200 Tie Rod
   / BX 2200 Tie Rod #1
tb4192
Just curious if anyone else has had this issue and how easy the fix is. I can turn the front wheels to the left but when I turn to the right the tie rod on the right side is hitting the wheel base. Is it as simple as replacing the tie rod? Picture is attached.
Thanks!
   / BX 2200 Tie Rod #2
I think you first need to check the bolts holding your hydraulic steering cylinder in place. It appears one may be missing, allowing the cylinder to rotate some.
The steering cylinder should be bolted tightly to the front drive axle with hex bolts and lock washers.
   / BX 2200 Tie Rod #3
Is it me or the tie rod looks crooked ?:confused:
   / BX 2200 Tie Rod #4
   / BX 2200 Tie Rod #5
Totally agree with Peter (Seymore). That cylinder rod should not move like that.. It is easy to replace a tie rod end, but I don't think that is your problem.
   / BX 2200 Tie Rod #6
Did you drive into something as in ran over somthing catching the tie rod:(?
   / BX 2200 Tie Rod #7
Looking at the picture, it appears that the steering rod, is bent. The rod should be parallel to the front axle case. In the picture it appears to be angled toward the axle case. Compair it to the other side to confirm.
   / BX 2200 Tie Rod #8
Yes it does look bent but it cant be if he can steer in the other direction. Those steering cyls have a single rod that extends thru the cylinder and out each end. If one end were bent it would bind badly in the other direction.
I think SetmourBota has it right.
larry
   / BX 2200 Tie Rod #9
It might be dragging, and not be noticed over the hydraulic assist present. My BX23 steering is so light, it only takes one finger to steer it. I would expect the BX2200 is the same.
   / BX 2200 Tie Rod #10
Yeah, understood. Bent as much as it appears Id be guessing yould need a 4# hammer to drive it in tho. I would sure like to know the situation. Too bad the OP hasnt come back...:confused:
larry
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
1985 Ford Ltl9000 Tender Truck (A53472)
1985 Ford Ltl9000...
