Brakes needed on 2nd axle?
   / Brakes needed on 2nd axle? #11
I think you'll be happy knowing you have the extra braking power when you need it. I wouldn't own a trailer that didn't have brakes on all axles! Again, you'll mainly appreciate the stopping power when you need it but it makes a big difference.
Jim
I am a trailer dealer and in Texas all that is required is brakes and a brake-away over 4,500# according to my book. It does not state "ALL AXLES" so one axle would be legal but get them on both for that type of load.
You will spend a little more now but save a lot down the road on upkeep of both the trailers brakes but also your trucks.
Chris
Thanks Chris for that clarification. I appreciate the input from all and will go with the concensus - all points make perfect sense.
   / Brakes needed on 2nd axle? #13
I don't understand how a manufacturer *could* offer brakes on only one axle. I get the laws only require "brakes" (Federal) if over 3500# and that it's assumed that the towing vehicle can stop up to 3500# safely, so if the trailer can stop the added 3500# (1/2 of 7k) the math works, but golly it's just not safe!
It's almost as bad as "suge" brakes, if you have even a partial failure on the towing vehicle or limited traction, you get next to zero braking from the trailer with them. What's the point in that????
IMO, Electric or Air operated braking systems should be MANDITORY (installed and functional) on all axles of all trailers over 1500# or any trailer towed by a vehicle where the GVW of the towing vehicle is exceded (small car or truck with a 3k # trailer for example).
There are only two safety systems on a vehicle that REALLY matter, steering and brakes.
I commend you for taking the high road!
   / Brakes needed on 2nd axle? #14
Here in Illinois, its a law to have brakes on all trailer axles and a break-away kit on trailers rated for 3K lbs and up. Most all single axle trailers now are rated for 2990 or under to stay under the 3K law.
If buying a new trailer over 3K, do yourself a favor and spend the extra $$$ and add electric brakes on all axles.
   / Brakes needed on 2nd axle? #15
If it has a single 3500 pound axle, it needs brakes, regardless of creative licensing tricks. If it has two 3500 pound axles, it makes good sense to have brakes on both axles. If it has 5000 pound axles or greater is must have brakes on both axles.
This is my rule for any trailer I would purchase to pull on public highways. If the state requires both axles to have brakes on a double 3500 # axle trailer it will have both brakes, as it should. Even that trailer may gross upwards of 7500 pounds or more depending on the tongue weight. In my opinion, which means something to only me, no trailer should be out there at highways speeds over 4 or 5 thousand pounds with a brake on only 1 axle. If you had to stop quickly that single axle will at best lock up and skid you right past your normal stopping distance by several hundred feet.
   / Brakes needed on 2nd axle? #16
I have brakes on both axles on my 7500 lb trailer, and there has been several times I was glad I did it. It only cost me $100 extra, though, and I considered it money well spent.
I can actually stop faster when towing the trailer (with a load) than I can without the trailer.
Oh yeah, get the Prodigy brake controller. I picked one up off eBay for $50.
   / Brakes needed on 2nd axle? #17
According to most state laws if a trailer is REGISTERED for 2999# or less (even if it has a 3500# axle) it is exempt from needing brakes (and in some states, titling and/or registration). For more info search on Google or ask Diamondpilot.
Aaron Z
   / Brakes needed on 2nd axle? #18
So where are the legislatures and manufacturers in this? In my opinion, safety is a BIG back seat to cost (registration and purchase). As brakes only add $100 to a $2000+ bill for the extra axle, where is the sense in building them w/o brakes on every axle?
Why would you pass a law that even allows such a loop-hole? It's certainly NOT in anyone's best interest to allow it, except someone might sell an extra trailer a year because the price was $100 less. Yea, that's a really good reason to sacrifice safety, not.
   / Brakes needed on 2nd axle? #19
Over here in Holland, brakes are mandatory on everything over 750kg/1650lbs.
I used to have a 750kg (untagged) trailer without brakes, to haul scrap, but i left the trailer at the scrapyard together with its last load. It was in such a bad shape that when they pull me over it would cost me a year of scrap money.
Anyways, i now have a big scrapbin which i load with the forks onto the brand new plywood floor (scrap would damage a floor: thats why i had a dedicated scrap hauler, but a bin saves my floor too) of my 2.6 ton (5700lbs) tandem hauler, brakes on both axles, and it tows so much safer even though i'm towing 50% more load on average. When i brake hard, i feel the rear end of the car slam to the ground because of the brake force applied by the trailer (center of gravity above the road surface will push down on the ball hitch when braking) instead of the trailer gravity pushing the rear axle of the car all over, despite the car being 50% heavier than the old single axle trailer.
When you have brakes on one axle, it will push me around just as hard as the single axle trailer without brakes. Just try it and judge for yourself. Why pay for airbags, ABS, adaptive cruise control, but cut corners on trailer brakes ? ;)
Even when loading 3 ton of silage bales on my trailer, behind my 1.5 ton S70, i cant drive faster than 70 or it begins to sway, (only on local farm roads) but at least i never ever have to worry about stopping: When sway occurs, i brake and it stops. I am looking for stiff rear springs of an estate so i can load some more on the ball hitch to prevent sway.
   / Brakes needed on 2nd axle? #20
Aaron Z
A trailer capable of weighing 3500 pounds plus tongue weight, but licensed at 2999 pounds may , as you suggest, be exempt from needing brakes per state law. It just isn't exempt from the law of common sense.
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2007 Sterling L9500 National Crane 1800 40 Ton Tri Axle Telescopic Boom Crane Truck (A55973)
2007 Sterling...
