M-6950 with a blown motor
   / M-6950 with a blown motor #21
I am looking for parts for a M6950 and I am located in Toledo Ohio Where are you located?
   / M-6950 with a blown motor #22
Hi, I am looking for parts for a Kubota M6950 and I am located in Toledo, Ohio where are you located? Thanks, George
   / M-6950 with a blown motor #23
MPS500AF--
-PM sent to you
   / M-6950 with a blown motor #25
Well I finally got a chance to drive the second tractor that we picked up for $1,000. It even came with a front loader as well. WOW what an awesome machine. This is the first Kabota that I've been around. This thing starts and runs great. It turns out that the 4wd problem it has should be simple to fix. There is a crack in a casting up by the drivers side wheel. The 4wd drive works fine. Just need to go to the donar tractor and swap this part out. I have a few questions. I would like to add another valve to run the loader so I can use the rear remotes. I'm sure that there is a power beyond port somewhere. Also is there any place on line that I could go to get a wiring diagram? Any help would be great.
Thanks,
Andy
Hi Andy, I am looking for the left side Hood Panel or complete Hood and Grille, I can be reached at 419-351-4707 mailmps@sbcglobal.net Toledo, Ohio Thanks, George
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
2006 International 7400 Dump Truck (A47477)
2006 International...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
