Rear Hydraulics & Must haves
   / Rear Hydraulics & Must haves #1
gdh
South Dakota
Kubota B3030 HSDC, Kubota ZD 18
I performed a search looking for the thread that I read recently that listed all of the reasons/implements that are run off of rear hydraulics. I cannot find it. Can somebody list the uses again? Are there any other "must haves" to consider before purchasing that are much more expensive to put on later?
Thanks
   / Rear Hydraulics & Must haves #2
What size tractor?
   / Rear Hydraulics & Must haves #3
Wow, could be a long list:
Hydraulic top/side links
Rear blade angle
Front blade angle
Grapple
4n1 bucket
Down-pressure on a PHD (post hole digger)
Lift on a post driver
Lift on a rotary cutter or any other implement
Hydraulically controlled rippers on a box blade
   / Rear Hydraulics & Must haves #5
Does that really matter?:confused2:
Well it would to me as what might be deemed "necessary" for my L5030 may not be for my BX2660 or 2305, but I guess you know more than I do, so I will stay out of it.
   / Rear Hydraulics & Must haves #6
I would never be w/o a hydraulic top link. my 2 cents.
   / Rear Hydraulics & Must haves #7
I don't know where that thread might be, gdh, but it boils down to just a couple of basic things:
1. Many implements use hydraulics to deploy/adjust/operate some part of the implement assembly. Really important on modern agricultural implements so most ag tractors these days are set up with rear hydraulics, but it's also used on some landscaper implements. A backhoe attachment may run off the tractor hydraulics since it saves the cost of a separate pto operated hydraulic pump. And, since larger tractors operate larger, heavier implements, at some point it's a necessity. My 6' brush mower doesn't need any hydraulics, but if you have a 15' batwing mower, you'd use hydraulics to extend/retract the decks.
2. You can set up hydraulics to adjust the 3 pt linkages so you don't need to do it manually, called top-n-tilt. This is really useful with a box blade, for example, where you often need to change the settings a bit when using it. If you are doing a lot of this type of work, it can be a real convenience.
If your expected work requirements for the tractor fall into one of these categories, you'll probably want a tractor set up with rear hydraulics, but keep in mind hydraulically actuated implements will cost quite a bit more than manual ones. If you're a weekend warrior like me, well, I can get off the seat and raise/lower the box blade rippers when necessary, since I probably only use them a few times each year.
If you have some specific uses in mind, share them here and I'm sure you get plenty of more specific advice about hydraulic remotes.
What size? Either a BX2660 or more likely a B3030.
Granddad4, As of now I am mostly thinking of front end uses. FEL, Snow removal with front end blower, ballast box. I am just trying to figure out how to configure the tractor without future regrets.
   / Rear Hydraulics & Must haves #9
Can't think of much you'd put on the front of a B3030 where remote hydraulics would be really useful except for a power angle snowplow or the snowblower you mentioned. I think the front mounted blowers offered by Kubota and others for the B series run off the mid-pto, but use hydraulics to rotate the discharge chute. That suggests you'd need one remote hydraulic control for it, unless it's included as part of the snowblower package. Maybe someone else who knows more about blowers will chime in.
If I had a definite need for one remote, I'd seriously look at making it a pair so it could also support a top-n-tilt setup on the back. Understand the OEM remotes from the dealer can be kind of pricey though. If you have a good dealer to work with, you probably should talk over the alternatives with him before signing on the dotted line.
   / Rear Hydraulics & Must haves #10
Maybe one set on the fron for a Grapple or 4 in one bucket, on a snowblower you need one for the deflector if its hydraulic. One to turn the chute if itys hydraulic both I believe are optional. And of course one to raise and lower. So yeah there are a few reasons to have a set on the front.
TMA (A49461)
TMA (A49461)
(APPROX 32) 6' X 12' HEAVY CHAIN LINK SITE PANELS (A54757)
(APPROX 32) 6' X...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
2013 Bobcat T180 (A47477)
2013 Bobcat T180...
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
