Matching Rotary Cutters (Brush Hogs) with tractor
   / Matching Rotary Cutters (Brush Hogs) with tractor #11
I used my old 4' rotary mower behind my Dad's old 9N, with an overrunning clutch installed.
I did not like it; 1st gear is tall. It felt like I was on a race car if I got the rpm up where it was cutting well.
I understand 8N's have the 4spd with a lower 1st gear than the 9N/2N, and mow better.
I have wondered how a Farmall Super-A would do with a rotary mower on the back. The Farmall-A I had for a while, had a lot better gearing and ground speed control than that 9N. I know the pto shaft might be at a big angle.
a N is good for a 5' cutter.
   / Matching Rotary Cutters (Brush Hogs) with tractor #12
Farmall Cub could run a smaller mower. It had to run a pulley assembly, and... the pulley ran reverse and different RPM.
Most mowers that run higher rpm are belly mowers.
I am not sure about flail mowers; maybe someone else could comment on those.
I've never seen a cutter rated for anything but 540 RPM (that doesn't mean there aren't any...but I've never seen one).
   / Matching Rotary Cutters (Brush Hogs) with tractor #13
To view most versatile brush cutting attachment on the market go to Chop-Zilla . Amazing machine!!
   / Matching Rotary Cutters (Brush Hogs) with tractor #14
untill you hit the 8spd boxes, IMHO.. most fords have tall gears.. the 3 spd an dthe 4 spds are the worst..
soundguy
2002 International 4400 SBA 4x2 (A49461)
2002 International...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2011 GR TRAILER GOOSENECK (A50854)
2011 GR TRAILER...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
