Mounting Roller pump to front pto
   / Mounting Roller pump to front pto #1
twarr1
Central Texas
I have an 8-roller Delavan pump that works great on the rear PTO but it is a little trouble to install and uninstall, and the pump is rated for 1000 RPM anyway, so I was thinking of mounting it permanently on the front (1000 RPM) PTO. The problem is, the front PTO has a ten spline 1" shaft. Does anyone know where I might find a coupler to fit this oddball? I went to the JD dealer, but apparently all the "standard" front PTO attachments use yoke couplings.
   / Mounting Roller pump to front pto #2
Use this search term "10 spline to 6 spline PTO adapter" in Goggle or another search engine.
It brought up several hits in Goggle including this one which is what I think you want.
   / Mounting Roller pump to front pto #3
What tractor are we talking about here? Most Mid-PTO's run at 2100 RPM, not 1000.
Sorry. I'm mounting the pump on our Deere 955.
RoyJackson - Thanks for the reply. I'll check that out, it might work!
   / Mounting Roller pump to front pto #5
No problem!
You might check your local Tractor Supply. They carry some adapters.
   / Mounting Roller pump to front pto #7
I am 99.999% sure that has a 2100RPM mid-PTO...
I think so too, but that would be at the engine's PTO RPM. He can always run the tractor at a lower RPM
   / Mounting Roller pump to front pto #8
I see the OP mentions a 'front PTO.' I don't know anything about the 955; but was a European style front PTO offered for the 955, or is the OP confusing the mid PTO with a true front PTO?
I know the 4200 - 4400 had front PTO's as options in Europe.
   / Mounting Roller pump to front pto #9
^^ Right.
I've got a Rear @ 540, Mid @ 2000 and Front @ engine speed :)
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2004 MACK CX VISION (INOPERABLE) (A52472)
2004 MACK CX...
2023 EXA INDUSTRIAL EXA INDUSTRIAL (A52472)
2023 EXA...
2022 KMC 21-37-HD LOT NUMBER 177 (A53084)
2022 KMC 21-37-HD...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
