Mounting Roller pump to front pto
   / Mounting Roller pump to front pto #1
twarr1
Central Texas
I have an 8-roller Delavan pump that works great on the rear PTO but it is a little trouble to install and uninstall, and the pump is rated for 1000 RPM anyway, so I was thinking of mounting it permanently on the front (1000 RPM) PTO. The problem is, the front PTO has a ten spline 1" shaft. Does anyone know where I might find a coupler to fit this oddball? I went to the JD dealer, but apparently all the "standard" front PTO attachments use yoke couplings.
   / Mounting Roller pump to front pto #2
Use this search term "10 spline to 6 spline PTO adapter" in Goggle or another search engine.
It brought up several hits in Goggle including this one which is what I think you want.
   / Mounting Roller pump to front pto #3
What tractor are we talking about here? Most Mid-PTO's run at 2100 RPM, not 1000.
Sorry. I'm mounting the pump on our Deere 955.
RoyJackson - Thanks for the reply. I'll check that out, it might work!
   / Mounting Roller pump to front pto #5
No problem!
You might check your local Tractor Supply. They carry some adapters.
   / Mounting Roller pump to front pto #7
I am 99.999% sure that has a 2100RPM mid-PTO...
I think so too, but that would be at the engine's PTO RPM. He can always run the tractor at a lower RPM
   / Mounting Roller pump to front pto #8
I see the OP mentions a 'front PTO.' I don't know anything about the 955; but was a European style front PTO offered for the 955, or is the OP confusing the mid PTO with a true front PTO?
I know the 4200 - 4400 had front PTO's as options in Europe.
   / Mounting Roller pump to front pto #9
^^ Right.
I've got a Rear @ 540, Mid @ 2000 and Front @ engine speed :)
MONOSEM NG-3 LOT NUMBER 229 (A53084)
MONOSEM NG-3 LOT...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
2007 INTERNATIONAL 4300 ROUSTABOUT (A52472)
2007 INTERNATIONAL...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
