Manual vs Hydrostatic
   / Manual vs Hydrostatic #51
Those two reasons are exactly why I traded in my 1988 JD650. What a difference now. Wasn't getting any younger.
   / Manual vs Hydrostatic #52
I dont even think its really a fair question these days.
I'm running a '63 Massey. THAT is a "manual" transmission. No shuttle, no power, no hydro. Cripes I dont even have power STEERING.
Any modern day manual variant (shuttle, power) would be light years ahead of what I have now. :laughing:
I fondly remember my Kubota 285DT. Manly-ma manual trans and no power steering, either. Tough as nails. :thumbsup:
   / Manual vs Hydrostatic #53
Get a GM truck with an Allison automatic. Works just like a medium duty automatic, but also have a manual shift mode so you can toggle through all 6 gears! :thumbsup:
I second that, an '11 DMax would be just what the Dr ordered!! :)
df.
   / Manual vs Hydrostatic #54
I think people lament hydro vs gear too much.
I've come to the conclusion it isnt in the direction change the hydro stands out. Todays modern "manuals" will get you 10 feet forward and 120 feet back as fast as the hydro's will. Where the hydro's shine in my opinion is in changing the speed of the direction your already going. If you do a lot of fast slow then get a hydro. If your doing a lot of forward reverse get a manual simply because it saves a few bucks.
   / Manual vs Hydrostatic #55
I don't hear it mentioned much about the Hydro/Geared discussion but I see the extra safety of never passing through a freewheeling situation while on steep hills. The shuttle has a autoclutch lag while it shifts so on a steep hill would you have to hold the brakes? The geared trans you have to push the clutch and pass through neutral and hold the brakes. The hydro you just roll back on the pedal and change directions not even hitting the brakes and not feeling like you are a foot slip away from a catastrophic joy ride. On hills it is great.
   / Manual vs Hydrostatic #56
Boy that's the truth. I do a lot of bush hogging with my Case and a ten foot rotary cutter along pond levies and on some I have to back down to the edge. I have shuttle shift and I am never comfortable doing this.
   / Manual vs Hydrostatic #57
What the hay - I'm old and I like automatic transmissions in my vehicles like 90% of rest of the population do.
So why on earth should I want to manually shift a tractor when I can press a pedal and have a smooth response - both forward and back?
Sorry - but old school sucks.
I think that you have just made up my mind for me.
Have had too many JOY rides downhill, while trying to
shift. EXCELLENT point! Thanks.:)
   / Manual vs Hydrostatic #59
Do you prefer an automatic or manual transmission in your car or pickup?
If you prefer not to shift like 90% of the population do, then buy a hydrostatic.:thumbsup:
My two cents and you are being overcharged
...and how much "shifting" do you suppose folk do on their "manual" transmission tractors ?
Somewhere between little and none; depress the clutch, select a range, select a gear and go.
Usually you will stop to select a different gear if the ground speed isn't quite what you want and just start over.
This isn't like a car or truck where you go up and down 5 or 6 gears to do anything.
I typically don't change gears on hills just because the grade has changed.
ymmv, etc and probably does.
   / Manual vs Hydrostatic #60
...and you would be fumble-farting around between gears on a steep down grade because ?
What is wrong with selecting the gear you want to go down the hill in BEFORE you get to the steep and nasty part ?
Oh, requires forethought - Gottit (-:
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
Scaffolding (A52377)
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
23169 (A50324)
23169 (A50324)
