What happened to HP ratings on small engines
   / What happened to HP ratings on small engines #21
What is the cubic inch displacement of the engine in your car/pick-up? I suspect part of the HP to CC is the global economy. The US has to adapt to the metric system used by the majority of the world.
CC, liters, cubic inch, etc. is probably a more consistant form of engine size
Roy
   / What happened to HP ratings on small engines #22
I was about to say the same thing, my old wheel horse with 12 hp seems to be about as powerful as my new husqvarna with a 24 HP briggs.
I had an old gravely 12 HP with a 50" mowing deck. That could EASILY out work the newer craftsman 17hp I have now. The gravely was just plain built better.
   / What happened to HP ratings on small engines #23
No offense, but what proof do you have for any of this blanket condemnation of today's consumer and blanket praise for older ones? The 'older and wiser' consumers wanted bigger, longer, wider cars with ever larger fins and designs that looked like fighter jets. Cars like this were bought out of 'need'? How many 'older and wiser' consumers knew how to clean an oil bath air filter or replace the points and condenser in a distributor? And it just had to be an 'executive' who decided to ship the different decals. Maybe all these changes have something to do with the EPA (click here)? Nah, couldn't be. Must be an evil corporation looking to deceive the uninformed, modern consumer. :confused2:
Mike,
That document explains a lot of things regarding emissions, but does it explain why the HP ratings are disappearing from the engine specs? I can't find it anywhere. :confused:
   / What happened to HP ratings on small engines #24
Some folks have mentioned displacement and comparing Cubic Centimeters (CC) to Cubic Inches (CI), but displacement has little to do with HP and torque. You can have a skinny cylinder with a long stroke or a fat cylinder with a short stroke and have the same displacement number. And there can be wild differences in HP and torque with engines of similar displacement.
They (whoever they are) should come up with and adhere to standard HP and torque measurement tests and require engine manufacturers to adhere to those tests if they want to advertise HP or torque ratings.
   / What happened to HP ratings on small engines #25
Mike,
I found a link that discussed SAE standards for small engines which mentioned getting away from hp ratings. The fact these changes are across many brands and engine manufacturers tells me this was an externally imposed mandate and not one company's effort to confuse the consumer which was the original rant.
   / What happened to HP ratings on small engines #26
I started poking around and found several references to lawsuits against Briggs and Stratton regarding multiple HP ratings for the same engine in Illinois back in 2008, I think. So B&S started listing torque. Apparently many of the other small engine makers are following suit.
What gets me is CC is useless as is torque as is HP alone. I want to know the torque and HP at the RPM before I know the CC.
For instance, I had a Yamaha motorcycle that was 396CC in displacement. Anyone that saw a Yamaha 400 CC motorcycle knew it was a dog back in the early 80's. Except mine was a 2 stroke twin, not a 4 stroke twin from the mid 70s. They'd see 400 on the side and start laughing at me until I ran an 11.9 in the quarter at 118MPH. Not bad for a 25 cubic inch motor. :D
That engine had very high HP for its size, but a very narrow torque range. 6 gears helped it.
I just wish the government would require small engine manufacturers to use a standard test to list HP and torque if they want to sell small engines in the U.S.
   / What happened to HP ratings on small engines #27
IIRC from something I read a while back is the engine manufactures label the HP, and possibly the torque, produced in that application. So if one application runs the engine wide open and another at 1/2or 3/4 throttle they label it with the numbers produced at that RPM. This would somewhat explain the variable numbers for the same engine.
I don't know that listing CC's is any better as already noted. But I guess we need some kind of number to compare against ;)
   / What happened to HP ratings on small engines #28
Yeah, I'm working on one of those little paint ball sized CO2 cartridges to setup NOS on my little 4 cycle string trimmer. You know, sometimes you get into some tall thick weeds and need a little more umph. I figure that holding that NOS button down will help me make it through those tough spots without having to buy a bigger trimmer. :)
Seriously though, take a 350ci GM engine for example. For the same displacement, how much do you think the HP varies for that same displacement engine in different situations? It seems that Honda sells boatloads, literally, of their 190cc engines. I have one on my Cub Cadet tiller, on my push mower and on my generator. However, when reading the owner's manual, the stated HP rating in the manual varies from 6.5 hp to 13 hp for that same engine. Percentage wise, that's a big difference.
   / What happened to HP ratings on small engines #29
The first time I found out that you can not tell much about an engine's speed or power from their ccs was back in 1960. I had a 150cc Simplex motorbike and a 150cc Harley Hummer.
The rich kid on the block got a new plastic girly-looking Honda 50cc that absolutely left me in the dust. Very embarrasing! :eek:
   / What happened to HP ratings on small engines #30
Change for the sake of change. Displacement is probably the only valid figure that can be used. Hp and several other "standards" are near usless.
What about an engine torque rating. As Moss Road pointed out displacement can have little to do with the power needed to operate a piece of machinery. Of course if we go back to a torque rating then wouldn't a proper {across the board} HP be the same thing?
Sorry but displacement is not a valid measure of power/torque needed !
2007 Trail-Eze TE80HT48DD 48ft 48 Ton T/A Hydraulic Dovetail Trailer (A51692)
2007 Trail-Eze...
Adams 5T HC Spreader (A53473)
Adams 5T HC...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A53473)
FIRESTONE 9.5L-15...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
2000 International 4700 26FT Box Truck (A51692)
2000 International...
