Those things to empty trailers?
   / Those things to empty trailers? #1
Eric_Phillips
Rochester, NY
FarmTrac 270DTC
What are those devices that are a long piece of tarp connected to a roller that attach to pick-up beds or trailers to help remove loose material from the bed?
Thanks Bob. I am trying to find an easier way to unload my 16' trailer. It is 6.5' wide so I am not sure if one of these would be the best solution.
   / Those things to empty trailers? #4
They really don't work that well...looks good in concept, not so good in application.
   / Those things to empty trailers? #5
Get a couple young boys and a cute daughter. They will come over and shovel it off.:thumbsup:
Chris
   / Those things to empty trailers? #7
*The one i have works 5 percent as well as a dump truck and 175 percent better than a shovel.
Like most parables that you post, I have no idea what you're talking about...not sure you do either.
   / Those things to empty trailers? #9
Do you seriously not understand what he's saying or is it just another case of you putting down everyone that doesn't agree with you as usual.
This isn't a Ford thread, not everyone has to agree with you... :rolleyes:
Obviously he's saying that a dump truck would be 20 times easier than a load handler but the load handler is almost twice as easy as using a shovel.
   / Those things to empty trailers? #10
Can you cite references to help with the hard words? Can you get the idea across with out so much hard math?
Pat
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2023 G Bar K Goose Neck Flat Bed (A53473)
2023 G Bar K Goose...
Frontier RT3042 (A50123)
Frontier RT3042...
2002 International 9200i Truck (A53473)
2002 International...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
