Baby Grand
Elite Member
- Joined
- Nov 12, 2007
- Messages
- 4,649
- Location
- Windsor, CT.
- Tractor
- Kubotas: L3240GST B2320HST B5100D & G5200H
Escavader-
If you examine geometry of the tongs, the pivot pins and points, you may observe that the hooks close together when you lift the attachment ring or hook due to the resulting angle. The closing force depends on this geometry and as the tong teeth get closer together that geometry (closing angle) changes and the closing force is reduced. I have a set of "blue" tongs that won't even close all the way - they stay about 4" apart when hung by the attachment hook. I suppose you could wrap a bungee cord around to force the points together on small diameter "tops" or do as some others have suggested and use a choker chain.
A related suggestion - I find that lifting a heavy log with the tongs is fine, but for safety I also run a choker chain wrapped around the log to a hook I installed on my drawbar. This way the tongs do the lifting, but the actual forward dragging force is tranmitted through the drawbar.
When hauling a log suspended only by the tongs from the 3pt hitch there is often the possibility that the butt of the log will dig into a stump, root or rock as you are moving forward. If this happens you will be in the s--t (but fast) if you don't stop. This all may happen before you even realize what needs to be done.
-Jim
-Jim
