Can the BX do it
   / Can the BX do it #11
Getting spot on advice so far - I would say you may not want to mess with the ones in the yard - it may frustrate you. You don't want to be disappointed with your new toy, er tool...:D. The FEL is not really the right tool for the job and you may make a bigger mess than you would like
Now, the ones down in the woods could be good practice for FEL technique - digging around the base to pop the roots then pushing them over and dragging 'em out
Are you getting a tooth bar?
   / Can the BX do it #12
I have an 1860, same frame, slightly lighter, same everything other than hp is my understanding. It's not a great stump remover. And yes, initially I was a little disapointed until I realized the B in BX does not apparently stand for bulldozer. Anything under 3-4" a chain, bucket full of dirt and 4wd will get them out, but anything bigger it isn't working. I will watch this thread with interest since I dropped a dozen trees or so. The shovel, ax, and chain travel to the woods with me every trip now. Sometimes there is not an easy way, I chop all my trees and limb them by ax, bad childhood memories of chainsaws. Don't like them, plus it keeps me pretty for my lady:thumbsup:
   / Can the BX do it #13
So, I am waiting for the new BX2660 and I am already planning things that I want to tackle. I have about 13 pine tree stumps (pic attached) that are anywhere from 6" to 10" around.
Think there is a way the BX can get them out without a backhoe?
Burn them with propane torch.
   / Can the BX do it
I didn't order a toothbar. That might be later on down the road if it is something that I will definately need to clear underbush.
   / Can the BX do it #16
I did one once from a tree that blew over in a heavy wind. Stump was probably 20" across. Dug at it with hoe for the most of the morning then took an axe to the root before I could lift it out with the hoe. It was a much bigger job than I anticipated.
   / Can the BX do it #17
JsBx - - attacking pine stump with a FEL would be a chore. Digging enough to cut off below ground grade/flush is good advice. Also the advice about leving a taller stump will definitely help the removal process. On the other hand, pines are a real challange [as are gum trees] - - the tap roots go down forever.
Jack
   / Can the BX do it #18
RatchetRake is better for cleaning underbrush. Toothbar is more for popping bigger rocks up out of ground, RatchetRake better for popping up smaller rocks and leveling out ground.
   / Can the BX do it #19
I dug out about a 12" pine stump with my BX and the FEL. It took a couple of hours and I ended up with a pretty big hole. The easiest is to cut if off flush, but its nice to get it out of the ground. Here is a couple of pictures of it. You will notice I left a couple of feet sticking out of the ground, and I actually pulled it out with my truck.
   / Can the BX do it #20
I wouldn't waste my time with the FEL. As others said you will just make a mess and probably end up bending something.
Rent a stump grinder and be done in 5 minutes on something that small. I have a few stumps and while a BH works well, it is still easier to eat them up with a stump grinder.
PALLET OF SHOP FANS (A58376)
PALLET OF SHOP...
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
(2) Seats (A57149)
(2) Seats (A57149)
(INOP) 2005 JCB 508C TELESCOPIC FORKLIFT (A58375)
(INOP) 2005 JCB...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
