SKIDDING LOGS WITH TONGS ;QUESTION
   / SKIDDING LOGS WITH TONGS ;QUESTION #41
Well Jim I am not sure of your math asscociations as I happen to be a guy that goes by experience (not saying you are incorrect). I am wondering if what you say is correct the more you lift that weight higher saying a 2000# pound log would weigh 1000# at lift when raised to a 45 * angle? The reason I say this is because the 3 pt I have on my tractor is rated at 850* at the draw bar. This lifts 2000* logs with ease which I think it could not do if that area of the log weighed 1000# Of course my tractor is only lifting this height maybe 6 to 8". I'm also going by the fact that in my prime, I could dead lift the end of a 20' 14" oak off the ground a few inches to get a choker under it. This is a log that would weigh close to 1000# and I do not think I was lifting 500#
I guess you'd know for sure of this tool's design functions if you called the company should you be interested in either purchasing or copying the design.
I suspect I value my experience & gutt feel similar to you and I don't trust my math either, so I usually ask someone to check it or I conduct an "experiment". Here's one you can try: take something heavy that's relatively long and of relatively unifrom cross section. An 8' Lally column, thick walled pipe, or an I-beam would be perfect. Set the middle of it on a bathroom scale and note the weight. Now set one end one the scale and the other end on a brick so it's about level. Scale should read about 1/2 the full weight. This is a simply suppoerted beam. Very similar to what we're talking about in the woods.
My initial reaction to the 500# max vertical lift limit was this: My 3ph is good for about 2600#, 24" aft of the lift point, so do I want to use an implement that only rated at 20% of that? They seem mismatched.
I have a boom pole, tongs, chains and associated links& hooks that I suspect is good for the full 2600# at a total cost of about $250.
-Jim
-Jim
   / SKIDDING LOGS WITH TONGS ;QUESTION #42
-Jim
-Jim
That means I was lifting way more weight than I thought I was. I wonder if that was the reason I've had 3 hernia operations. I was looking at it like tongue weight on a trailer where weight on the tongue would be way less than what the weight of the trailer would be. Of course the trailer would be a bit of a balanced load but a hitch capable of only 500# of vertical weight is capable of pulling at least a 7000# trailer load. I figured a logging tool capable of a 500# lift would at least be able to pull a 2 or 3000# log. Do not know enough about this type of physics to refute what you are stating so I have to leave it at that and contend with your observations as certainly possible to be correct . Thanks for the discussion.
UNUSED RAYTREE RMLS18T WOOD SPLITTER (A51248)
UNUSED RAYTREE...
John Deere 772-A Grader (A52384)
John Deere 772-A...
HEAVY DUTY TRACTOR BRUSH GUARD (A51247)
HEAVY DUTY TRACTOR...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
