Broken piece in joystick...where to get part?
   / Broken piece in joystick...where to get part? #21
It's a high stress part. I'd be surprised if adhesive will work. If you can do a solvent weld on the plastic ... maybe.
It looks like a simple part you could carve out yourself if you want it stronger than original. Pick the material you want to use and order some. I could make that with a drill, a saw, and a file. (I don't see how it's attached to the metal - possibly an M6 tap required?)
McMaster-Carr
You could even make the new one out of metal if it can be kept greased..
Of course if the OEM part is less than $30 and if you think the design is okay just order it. If it's $10 or less order 2.
   / Broken piece in joystick...where to get part? #22
Called my dealer today, now they can get part! Sorry Dave, rather keep the money here in WV and I really like my dealer. After I had tractor awhile, I thought everything leaked down to fast. Told them and they came and got it, 35 miles one way, tested it overnight and brought it back. When he did, he gave me extra bolts for the swing chain. Didn't charge me anything! Aaron
   / Broken piece in joystick...where to get part? #23
Glad your local dealer could help, that is the way it is supposed to work. Does your dealer happen to be Tractor Pro?
McMaster-Carr
Do you think model cement would work? It melts the plastic, but I know model plastic is probably softer than this plastic.
The hole has a little divet in it, if you were to look at it in cross section, it would be a very rounded 'M' shape. The ball that is attached to the joystick sits in the divet in the middle of the 'M'. Don't know if that makes any sense.
I was going to drill some holes through both pieces at an angle then put the JB Weld in these passages and hope the cross direction of them would add strength. If not, I'll order one.
Thanks everyone.
   / Broken piece in joystick...where to get part? #26
Thanks everyone.
I think you are wasting your time. Order the part and assemble your valve once then get back to work.
   / Broken piece in joystick...where to get part? #27
Buy it or make it.
I went ahead and ordered the part....
Just and update, I ordered that part, put it on and it works fine.
Now there is another one broken........
   / Broken piece in joystick...where to get part? #30
Well! just broke another! don't know how many that makes, but will take them to a machine shop this time and get two made outa metal!!!!!!!!!!!!!!!!!!!!!!
2003 Chevrolet Silverado (A53314)
2003 Chevrolet...
kids dirt bike (A53424)
kids dirt bike...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
New/Unused 10ft X 20ft Single Garage Metal Shed (A54865)
New/Unused 10ft X...
2003 Ford F-750 12ft Flatbed Truck (A55788)
2003 Ford F-750...
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
