Where did my SUDT go?
   / Where did my SUDT go? #31
The difference in the fluid level with the cylinders retracted verses extended is the volume that the cylinder rod displaces. I figure on mine it might be a gallon or so difference.
Thanks jinman, that makes sense.
As for the position of the cylinders, isn't there fluid on both sides of the piston in these cylinders? (This may be stupid, I don't know anything about hydraulics.)
   / Where did my SUDT go? #33
There is fluid on both sides of the piston but when the cylinder is fully extended the cylinder will hold slightly more fluid because the rod is extended to the outside of the cylinder and and fluid now fills the space of the rod. The same reason the cylinder is not as strong on the retract as it is on the extend because of the are of the rod.
   / Where did my SUDT go? #34
Good point on that one. It's easy to take the cylinder rod for granted. It's hard to tell what mine does.
One thing for sure, Sight glasses suck.
   / Where did my SUDT go? #35
Possible places the SUDT went without thinking catastrophic thoughts:
slight evaporation over time
drips when attaching/detaching hoses ..FEL or other hydraulics
filling replacement hydraulic filter
cylinders extended on attached equipment
filling new hoses or cylinders on equipment .. depends on what you attach to it:)
   / Where did my SUDT go? #36
I like my old Ford.
Place tractor on a level surface. Remove level plug. Fill with UTF till fluid runs out level plug hole. Replace plug. Repeat next time something seems to be moving slow or the following year. :D
Wedge
2019 D&P WELDING  12FT LUBE TRAILER (A52472)
2019 D&P WELDING...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
2015 Ford F-150 Ext. Cab Pickup Truck (A50323)
2015 Ford F-150...
KUBOTA M7-132 (A53084)
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
