where to hook a chain to pull with BH on?
   / where to hook a chain to pull with BH on? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
My BH stays on a lot. I aften want to use the tractor to pull something, It was a Van, then it was pulling trees down, now it's pulling a stump again.
Where do you hook to the tractor when the BH is on?
When I was pulling trees down with ropes and chains I went thru the holes in the BH subframe. This pull was only a medium pull so I just looped it on the BH base.
   / where to hook a chain to pull with BH on? #2
I do like you did, keeping the hitch point(s) low and near attaching points. To me that is the safest for both operator, bystanders and the equipment.
   / where to hook a chain to pull with BH on? #3
You could weld the suitable clevis hook to the back of the bucket.
   / where to hook a chain to pull with BH on? #4
Don't even think of pulling with the bucket. There is no relief valve in the dipper stick hydralic circut to prevent overloading the dippper stick. A darn good way to bend a cylinder rod or worse.
   / where to hook a chain to pull with BH on? #5
Then why could you not bend it when digging then?
   / where to hook a chain to pull with BH on? #6
When digging, the system presure relief valve will prevent overloading the hydralic circut. When pulling with the tractor, hooked to the bucket, you do not have the protection of any relief valves.
   / where to hook a chain to pull with BH on? #7
Ron I just was not thinking that through. It would be OK if you were using the backhoe dipper to do the pulling if you had your stabilizers down.
   / where to hook a chain to pull with BH on? #8
I welded a "D ring" to the back of the bucket and keep a clevis with a chain hook on it under the seat when I need it. The D ring stays flat when digging and is pritty much out of the way all the time,,
   / where to hook a chain to pull with BH on? #9
I use the draw bar.
I don't know of a better solution, but if you have one I would be interested.
   / where to hook a chain to pull with BH on? #10
I can't get to my drawbar when the back hoe is on. I just pull from the front whenever the hoe is on the tractor. I have a spot to hook on the frame up front.
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A52472)
2012 TEX MEX...
2012 FREIGHTLINER CASCADIA (A52472)
2012 FREIGHTLINER...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2005 TerraGator 8104 (A52748)
2005 TerraGator...
