where to hook a chain to pull with BH on?
   / where to hook a chain to pull with BH on? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
My BH stays on a lot. I aften want to use the tractor to pull something, It was a Van, then it was pulling trees down, now it's pulling a stump again.
Where do you hook to the tractor when the BH is on?
When I was pulling trees down with ropes and chains I went thru the holes in the BH subframe. This pull was only a medium pull so I just looped it on the BH base.
   / where to hook a chain to pull with BH on? #2
I do like you did, keeping the hitch point(s) low and near attaching points. To me that is the safest for both operator, bystanders and the equipment.
   / where to hook a chain to pull with BH on? #3
You could weld the suitable clevis hook to the back of the bucket.
   / where to hook a chain to pull with BH on? #4
Don't even think of pulling with the bucket. There is no relief valve in the dipper stick hydralic circut to prevent overloading the dippper stick. A darn good way to bend a cylinder rod or worse.
   / where to hook a chain to pull with BH on? #5
Then why could you not bend it when digging then?
   / where to hook a chain to pull with BH on? #6
When digging, the system presure relief valve will prevent overloading the hydralic circut. When pulling with the tractor, hooked to the bucket, you do not have the protection of any relief valves.
   / where to hook a chain to pull with BH on? #7
Ron I just was not thinking that through. It would be OK if you were using the backhoe dipper to do the pulling if you had your stabilizers down.
   / where to hook a chain to pull with BH on? #8
I welded a "D ring" to the back of the bucket and keep a clevis with a chain hook on it under the seat when I need it. The D ring stays flat when digging and is pritty much out of the way all the time,,
   / where to hook a chain to pull with BH on? #9
I use the draw bar.
I don't know of a better solution, but if you have one I would be interested.
   / where to hook a chain to pull with BH on? #10
I can't get to my drawbar when the back hoe is on. I just pull from the front whenever the hoe is on the tractor. I have a spot to hook on the frame up front.
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A51573)
2004 Ranger 195 VX...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
