Any tips for 1 man implement hook-up?
   / Any tips for 1 man implement hook-up? #91
In ten minutes with IMatch I can pick up (move over to mow beneath) 4 ot 5 implements without getting off the tractor.
Are they all JD implements? Does the Imatch spacing work with other brand implements? I have Woods and Bush Hog attachments.
Ken
   / Any tips for 1 man implement hook-up? #92
does it hookup the pto shaft for ya? :)
deriously though, whatever works, and every lil bit helps.
( speaking of auto pto shaft hookup... havn't I read that deer has something like that in limited release? )
soundguy
I haven't added the auto shaft portion to my IMatch but it is available for my implements. I did try it at the dealer and it works pretty slick, for someone starting out with a clean slate (no existing equipment) I think it is a good way to go.
When I am moving my implements to mow beneath them I don't need to hookup the pto anyway. I have fixed link, telescopic link and IMatch and the latter is much easier to use by myself.
   / Any tips for 1 man implement hook-up? #93
Ken
Ken,
The IMatch will work with most Cat 1 implements though some need modifying. There are a few that would require major changes to work. Once you have them setup though the IMatch is a joy to use.
Having the IMatch and knowing what it needs to work I am aware and pay attention to this when buying future implements. I have a variety of brands of implements and most have needed only simple modifications to make them work.
   / Any tips for 1 man implement hook-up? #94
My only tip is to make sure the wife or kids arent around. Dont want them to hear you cussing. :thumbsup:
   / Any tips for 1 man implement hook-up? #95
Good boots(as hammers):thumbsup:
   / Any tips for 1 man implement hook-up? #97
42 oz. deadblow mallet.
That and a good pry bar can make things a lot easier. Park your stuff on pallets with wheels on them if they are on concrete.
   / Any tips for 1 man implement hook-up? #98
+1 on the mallet and prybar -- I have a six foot "railroad pry bar" that I always use when attaching implements -- I have a quick hitch but find it kinda a waste of time :eek:
   / Any tips for 1 man implement hook-up? #99
How do you find it a waste of time?
I find the brute force method to be a waste of time, growing up we didn't have I Match and had to use the brute force method. If you take the time once to make the quick hitch work it saves a great deal of time. I find that the quick hitch combined with top n tilt makes a good combination.
When I build implements I make sure they are compatible too. Usually a few simple modifications and most implements can be quick hitch ready. Guess it helps to have some welding equipment but with what I know now I would pay a welder to do the work if necessary.
   / Any tips for 1 man implement hook-up? #100
After getting the iMatch, I don't need any of the bars or heavy boots or heavy mauls to hook-up. It is a real pleasure compared to the sweating that I used to do. Now I will admit to a tilt a time or two, just because the implement shifted or I approached at a different angle, and admit that the hyd. top arm is a real blessing as well. But no sweat now. :thumbsup: :cool2:
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
2011 Ford Explorer SUV (A53424)
2011 Ford Explorer...
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A57193)
UNUSED FUTURE MINI...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
Cushman Electric Cart (A55851)
Cushman Electric...
