Need help with axle seal behind hub on a 3320
   / Need help with axle seal behind hub on a 3320 #1
XviperX2
Lehigh County, PA
JD 3320 ehydro
I lost all the fluid in my front axle after a 12 hour day of digging and moving dirt with my FEL, I am sure it is just the seal after reading some other posts on here but I am stuck?? I have removed the clip and tried to use an 8" gear puller on the gear but i cant get the bearing to move at all. What am i doing wrong??? Thanks for any advise you can give!
   / Need help with axle seal behind hub on a 3320 #2
My hub is the same. I used a press and pushed on the shaft once the
circlip was removed. As I recall, you can't get a puller behind the bearing
by itself. Spicer uses interference fit bearings, unfortunately.
   / Need help with axle seal behind hub on a 3320 #3
As DF said use a press. I hope you too the c clip off before trying the puller.
Matt;)
Thanks i was able to get it with the gear puller. once i had it as tight as i could i hit the center screw on the puller, it broke free then came off fairly easy.
   / Need help with axle seal behind hub on a 3320 #5
Do you by chance have a pic of the puller setup that you used?
Glad it worked for you, and some of may be faced with the same problem sooner or later. :)
Thanks
   / Need help with axle seal behind hub on a 3320 #6
The correct tool to put it back on is a press, too, but I suppose a
hammer will work.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
Kubota Snow plow with subframe
Kubota Snow plow...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
2017 FORD E-350 SUPER DUTY 16' BOX TRUCK (A60430)
2017 FORD E-350...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
