tiller question?
   / tiller question? #1
who-dini
nova scotia
landini 4740
hello, i just picked up a tiller(howard hr 7-50 hd) and noticed the recomended hp range is 22-35 hp so will this tiller self destruct on my 45hp tractor? i bought without researching as it was priced right
also is howard a good make? thanks
   / tiller question? #2
Yes, Howard is very good. If you go slow and use your head, you should not have any problems. Does it have a slip clutch? That would help protect it. How is the soil? rocky and or roots?
   / tiller question?
yes it does have slip clutch,soil is mixed bit of everything, i will search slip clutch and learn how to set up so i dont break chain hopefully, thanks
   / tiller question? #4
If it were me I'd just run it at lower than PTO speed. You really don't need that sort of engine speed to till anyway so keeping it about 500rpm shy of PTO speed would put you right back into the recommended horsepower range.
   / tiller question? #5
Dropping the PTO speed just a little like IT says will also save you a lot of fuel.
   / tiller question?
will do,thanks again:thumbsup:
   / tiller question? #7
Yep, fuel and noise and wear on the tractor. I probably run PTO speed (2500-2600) for 5% of what I do and the rest is done perfectly well at 1800 (BH, loader work) to 2100-2200 (most mowing). I also prefer not listening to the full tilt boogie at PTO speed which is noticably louder even with appropriate ear protection.
2001 Freightliner E-One Pumper (A52377)
2001 Freightliner...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
