How long of a trailer to get?
   / How long of a trailer to get? #21
I dont see many 20' equipment trailers, just a few offered as options, much less 22' and up. Who are some manufacturers? I shouldn't need a 10+ ton trailer for this. Want to keep it pick up sized.
You can probably find a 20' 7000 lb trailer with 3500 lb axles. You may need to go to 5200 lb axles and 10,000 rating to get 20-22'. You can probably order a 20' trailer but may have to wait a couple of months to arrive. It does not cost much to add 2-4' to a trailer when it is made. 16-18' trailers are more commonly requested by buyers and is usually what are sitting on the lots.
   / How long of a trailer to get? #22
You can double the empty weight by crossing over certain points too. It is just not an axle issue but from hitch to ramps issue.
   / How long of a trailer to get? #23
hear is my 20' full of tractor and stuff.
   / How long of a trailer to get? #24
Nice setup. Where did you get the tool box? I have been looking for a box that will not interfere with the jack.
   / How long of a trailer to get? #25
I assume the person who made the trailer (its home made from best i can tell) welded up the tool box. like 1/8" diam plate steel. came on the trailer (welded to the front)
   / How long of a trailer to get? #26
IMHO, almost anyone considering purchase of a trailer for hauling heavy equipment should seriously consider a gooseneck setup. I believe that when the situation turns risky, for whatever reason, and there can be many reasons...not all within the driver's control, that this setup is significantly safer than a bumper pull.
Consider a bumper pull improperly loaded with much weight on rear bumper, lifting weight from front/steering tires. Now, take this rig around a tightish curve at 40 mph and execute a panic stop because somebody pulls out in front of you. Guarantee you a similarly weighted gooseneck will come out far better than the bumper pull.
I grant that a gooseneck takes more skill/time to hookup and that it is embarrassing when you forget to lower the tailgate;)
Well said - I could not agree more...
A gooseneck is far and away more stable and controllable than a bumper-pull.
I put an M&W hitch on my Dmax and using the bed is not an issue.
AKfish
CAT 350E2 Haul Truck (A55272)
CAT 350E2 Haul...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2012 Ford Transit Connect Van, VIN # NM0LS7DN0CT092703 (A57453)
2012 Ford Transit...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
New/Unused AGT Industrial 70-inch Seeder (A57454)
New/Unused AGT...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
