Dust control for gravel lane
   / Dust control for gravel lane #31
My well is low on oil, but that doesnt mean it needs a supplement.
larry
   / Dust control for gravel lane #32
I wish that my well was full of oil, but no such luck. :laughing:
   / Dust control for gravel lane #33
In Quebec the cities and towns use a wood resin that they spray liberally on dirt roads.
Considered to be eko friendly and OK near lakes and streams.
The application is done with an old oil tanker type truck that has a pipe that is a bit wider than the tanker truck with holes every 6 ins or so.
They simply rely on gravity to apply this gooy resin liquid.
Works well, gets soaked into dirt road bed and lasts the whole summer.
   / Dust control for gravel lane #34
A couple of bags of water softener salt (the fine ground stuff) applied during a rain shower (not a soaker) with a lawn spreader can help immensly. Road commission uses the same deal. Best overall solution for me was to top it with crushed asphalt (locally available). It was $300 for 10 yards as I recall. The guy set his tailgate to about 2" opening and drove about 15 mph. It resulted in about 1.5 inches of covering. A perfect, quiet, dustfree, stays put material. And its dark colored. For some reason the color sets it off from other's driveways. It packs down real nice, too. Some folks use a plate compactor to really compact it.
Thanks for all the replies and suggestions. I think I will probably try either liquid or dry calcium chloride. The question now is where to buy it.........like so many other things if I could find it in bulk at near wholesale pricing its probably doable. If its retail maybe not since I have a fairly long lane. I'll post when I actually put something down.
   / Dust control for gravel lane #37
CaCl is usually available at masonry supply yards or concrete batch plants. MikeD74T
   / Dust control for gravel lane #38
I'd suggest taking the potential hazard of walking Fido on a salt treated surface into consideration. Not sure about the effects, just a gut feeling that it couldn't be good if done often.
   / Dust control for gravel lane #39
   / Dust control for gravel lane #40
I' m sorry I can't be specific but our municiple govt. did a test by our yard and 2 or3 others last year I heard it was residue from feed mills and something else it was sprayed on with a water truck or something like is used on road repares then wet with water once more a few days later ,0 dust off it all summer even fast traffic not quite as good this year but better than nothing.
2006 Ford F-150 Pickup Truck (A50323)
2006 Ford F-150...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2002 Sterling M7500 Acterra Lift-All LA04C51 51FT Insulated Forestry Chipper Bucket Truck (A50323)
2002 Sterling...
2017 Nissan Sentra Sedan (A50324)
2017 Nissan Sentra...
KSI Conveyor (A52748)
