Transporting with the loader in the air
   / Transporting with the loader in the air #11
I saw an idiot do that with the loader on the trailer going the other way on I-76 one day. I would have gotten cell phone camera pics; but I would have had to be an idiot too in order to get them while driving.
I see fools mow with the loader up as high as it will go around here quite frequently. The only time I put the loader up high is when I'm near the neighbor's vinyl 3-rail fence, then I immediately lower it when I get parallel to the fence.
I usually keep the bucket on while mowing out of laziness; but if I do mow the scary ditch out back as I call it, I like to have the bucket on, front edge up, and bucket lowered to just above ground level to add a little extra stability. I now let the county deal with their ditch since they have one of those nice Land Pride boom mounted mowers just for ditches.
   / Transporting with the loader in the air #12
yep.. the implement should have a tie down on it..
soundguy
   / Transporting with the loader in the air #13
I have seen a couple of times as well, ussually in a dump trailer that is too short to hold it with the loader down. The biggest risk would seem to be raising the center of gravity, espeically when the "deck" of a dump trailer is higher than the deck of an equipment trailer.
   / Transporting with the loader in the air #14
I'de be worried about low hanging obstacles.. like bridges!
soundguy
   / Transporting with the loader in the air #15
That idiot must be related to the idiot I saw last weekend that was transporting his Massey Ferguson, (at least a 1533 or larger tractor), in a dump trailer that was too short, and he too had the loader lifted high up in the air as he went down the road.
   / Transporting with the loader in the air #16
I too see it out here but most of the time there is a few implements stacked on a rack in front of the tractor and the loader rests on the top of the rack. Otherwise, it is a dumb idea. They usually chain the bucket to the rack.
   / Transporting with the loader in the air #17
NOT LEGAL!!! check fmcsa
it has to be on a solid surface and it has to be chained (restrained) down unless it is mechanically pinned in place. (not just hydraulics)
+1 D.O.T here scalded our low-boy driver with a warning because the blade of the komatsu D-65 was not "chained' down because it was not mechanically "pinned" in place. Our low-boy driver could not hold himself back and told the D.O.T fella, Yep... its a real pain in the arse when a 12 foot, several thousand pounds of u-blade just "blows" off.....:thumbsup:
But a FEL reaching for the sky in transit DUH.... get a trailer or any transport item the right length and don't endanger yourself or more importantly, anybody other than you, or there property.
   / Transporting with the loader in the air #18
In the last ten years, there have been two bridges hammered by TLB implements in the air. Caused quite a bit of damage to both bridges. Sometimes you have to wonder what is going on in the driver's head:confused2::confused:
   / Transporting with the loader in the air #19
I was behind a big Semi Truck one day going down a divided highway ...he was in one lane and I was in one next to him but I was about 200yrds behind him when he ran up under an overpass at about 60 MPH...sure did stop him quick and peeled the top of his trailer back like it was a tin can..I had to keep going due to traffic...but I'll bet from now on he pays attention to the clearance signs on the bridges and overpasses...LOL
   / Transporting with the loader in the air #20
what's wores is I've seen signs that were wrong due to pavement overlays.. now that ones scary to think about for sure!
soundguy
MANIFOLD TRAILER (A58216)
MANIFOLD TRAILER...
Kubota M6 131 HP
Kubota M6 131 HP
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
2015 Kenworth T800 National NBT60 60 Ton Six Axle Crane Truck (A60460)
2015 Kenworth T800...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
