2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
Item Details
Auction ID
55315
Make
Kubota
Type
Ag Equip
Year
2023
Auction House
Fastline Auction, LLC
Model
AM450H
North Carolina
Horsepower
65
Description: Kubotas M4 series represents comfort, performance, and efficiency. This ideal chore tractor for small cattle/ hobby farm applications gives the tools needed to quickly and efficiently complete a days work. These tractors are packed with premium and ergonomic cab features built for operator comfort. The M4 Ultra Grand Cab II is one of the largest in its class. The overall air circulation in the cab has been optimized by the cabs rounded glass to keep you cooler on hot summer days and warmer on cold mornings. The Ultra Grand cab also comes with a suspended seat to absorb shock and reduce operator fatigue. In addition, the spacious platform allows for plenty of legroom and maneuverability. This ideal chore tractor is capable of running heavier workloads while maintaining high maneuverability with Kubotas bevel gear front axle. This will provide the tractor with greater all-around performance. Whether you're in the tight confines of a barnyard or going in and out of windows, this M4 series will prove its class leading turn radius. LED work lights give the operator extra hours in the field by providing a bright 360 degree range of vision. Additionally, the glass roof panel as standard equipment, increasing visibility and operator control while the loader is being operated at full height. At the rear of the tractor, the high 3-point lift capacity of 3,307Ibs makes this tractor capable of tackling many tasks. The hydraulic independent PTO clutch can easily and quickly be engaged and disengaged on the go. This means mowing and operating hay equipment are all made more efficient. Hydraulic wet disc brakes require less pedal effort and retain high performance even after repeated heavy-duty work. M4 Deluxe: - Deluxe operator seat, standard operator seat, 2 rear remote valve (SCD, FD), electronic 4WD engagement, LED work lights, economy PTO, and PTO lever located inside the cab Year: 2023 Make: Kubota Model: M4-061 Deluxe Serial No.: KBUM3BDCCN8G10291 Hours: 34 Meter Reads: 34 Engine Manufacturer: Kubota Engine Model: V3307-CR-TE4 Cylinders: 4-Cyl. Horsepower: 65 Transmission: 12 Speed Drive: Mechanical Front Wheel Drive (MFWD) Fuel Type: Diesel Lift Capacity: 3307 Front Tire Size: 320/70R24 Rear Tire Size: 420/75R34 Enclosed Cab: Yes FASTLINE SALES REPRESENTATIVE(s) Nick Herring nick.herring@fastline.com 919-922-2854 Item Location - Address: Provided by Seller Item Location - City: Greensboro Item Location - State/Province: North Carolina Item Location - Postal/Zip Code: 27405 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
see lot description, multiple locations, KY 40010
Starting Bid: 28000.00 USD
Auction Finishes: November 18, 2025 at 07:34 PM
Click Here To Bid Now!
Happy Bidding!
2012 Ford Transit Connect Van, VIN # NM0LS7DN0CT092703 (A57453)
2012 Ford Transit...
CAT 930M (A58214)
CAT 930M (A58214)
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2018 INTERNATIONAL...
