How thick is the metal on the Bobtach?
   / How thick is the metal on the Bobtach? #1
galaxie428
Gold Member
Rushville, IN
Bobcat CT230
I have the Bobtach on my 230 and I just ordered some 3/8 hooks from AW Direct to weld on. I read somewhere, maybe in this forum or maybe in the customization forum where someone welded the hooks on the bobtach on the loader. I thought that sounded like a pretty good idea so I think I will do that instead of welding them on my bucket.
I just wondered how thick the metal was on the bobtach or if I need to reinforce it with 1/4" or thicker. Any thoughts?
   / How thick is the metal on the Bobtach? #2
I was going to weld some hooks onto my bucket, but before I got to it, I needed a way to hook a chain to my bucket to lift an old trailer that I was scrapping.
I got to rummaging around in the barn and found a construction shackle, and it fit the brackets that are existing on my bucket ( im not sure why they are there, and havent noticed them on any of the pics I have seen on here) but that shackle worked great, and I have left it there. Hasnt seemed to bounced or even scratched the paint so far.
I think I will forgo the hooks unless I find I need them down the road
   / How thick is the metal on the Bobtach? #3
can you give us a pic?
   / How thick is the metal on the Bobtach? #4
That might have been me.
I did use a reinforcement plate. The Bobtach carcass seems robust, but
the 1/4" plate I used will avoid problems. I really like how it works: I can
lift much more weight with the bkt off. I prefer slotted 1/2" steel to
hooks as they allow easy detachment (roll back and the chain drops off).
   / How thick is the metal on the Bobtach? #5
I will get a pic of it today and try to post it tomorrow
Yes, I think it was. I remember seeing your pic now. I thought it might be the safe bet to add some additional metal but I just hate to spend the money to buy it. Most of the stuff I have used in the past is scrap that I have found somewhere but I have yet to find anything as thick as 1/4 plate.
   / How thick is the metal on the Bobtach? #7
I bought the same hooks as you got. I welded them onto 1/4" plate about 4" x 3" and then bolted them on with (4) 5/16 bolts each. I have the standard bucket which is 11 gauge (.1196") thick. I thought that was a little thin to be welding directly to. The hooks are mounted forward as possible, the nuts on the underside are right up aginst the rolled edge.
I use mine almost every time I've got the tractor out.
   / How thick is the metal on the Bobtach? #8
My bucket is different than your , If they bring it back to me tonight and it isnt storming I will try to get pics of it
   / How thick is the metal on the Bobtach? #9
Arch, here is the pics of my shackle and bucket.
It is attched to brackets that I have on both sides of my bucket.
I do not see these any on anyone elses bucket in pics I have seen posted on here, Im not sure if I got a ******* bucket or if it was built for putting a grapple on it
   / How thick is the metal on the Bobtach? #10
No ******* bucket. I have that one too. The pin on bucket is totally different. I think our bucket is a skidsteer bucket.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
DEUTZ MARATHON...
2021 Caterpillar 308CR Midi Excavator (A55973)
2021 Caterpillar...
2010 Ford F-150 Pickup Truck (A55973)
2010 Ford F-150...
Enerpac Hushh-Pup Hydraulic Power Unit, Model Per-132, Product Code B14880, 1/3 HP, 120 Volts, 1 (A59076)
Enerpac Hushh-Pup...
