Is a L2800 too big for a yard?
   / Is a L2800 too big for a yard? #1
jkruer01
Member
I was wondering is an L2800 is too big/heavy to use to cut a yard with. If you used a finish mower on an L2800 would it tear up the yard? Would it matter what kind of tires are on the tractor? Which tires would be best?
Thanks!
Jeremy
I am looking at a 4wd if that matters at all.
Thanks!
Jeremy
   / Is a L2800 too big for a yard? #3
Thanks!
Jeremy
My cousin has a L3430,72"MMM,FEL, Ag tires and it does just fine
   / Is a L2800 too big for a yard? #4
I think it would depend on the yard. Are there very many obstacles? Are there wet or soft spots? If it is big, wide open, and dry, sure you can. I certainly wouldn't recommend ag tires or putting it in 4 WD. The L2800 is a dang heavy lawnmower. Actually turf tires may be right choice. Good luck!
cj
Thanks for the feedback. I appreciate it.
Jeremy
   / Is a L2800 too big for a yard? #6
Well, I have to admit on a few occasions when I had my cabbed CX80 and 8' finish mower up here doing other stuff, I have used it to mow my yard, but my preference is for something lighter and more maneuverable than than an L2800.
   / Is a L2800 too big for a yard? #7
I use a 1720 NH with a 6' RFM on my yard with AG tires. The tractor has a shipping weight of 2800# but has loaded tires so I calculate that the tractor weighs in around 3300#. With that said, the tractor and mower is not too heavy for my yard. I don't mow with the 4WD in and try not to make too sharp turns.
As far as tires are concerned, if you are just going to mow with the unit I would get turf tires. Most people use industrial tires as a compromise and would be easier on your turf than AG due to the wider footprint.
With all that said, you will be fine with the L2800. Just make sure that you don't have too many trees or other obstacles in the yard that wouls slow you down.
   / Is a L2800 too big for a yard? #8
If you don't need to engage 4wd to mowe also take wide turns shall help the turf.
Will you have fel attach when mowing?
   / Is a L2800 too big for a yard? #9
Hi. I,m mowing with my Massey 1643, industrial tires, it weight +- 4400 pounds. When mowing I take off the loader. Always use the 2wd because on 4wd on sharp turns, the front tires are damaging the turf (try to avoid sharp turns even on 2wd and on dry land it is safer for your turf). If your only use is mowing, turf tires would be a good choice. Good luck:thumbsup:
   / Is a L2800 too big for a yard? #10
Thanks!
Jeremy
I think it's really going to depend on your particular situation. My grass grows for nearly 8 months a year. At the start of the year and again at the end, my B series with R1s will rut up the yard due to ground conditions. We are in a drought right now so everything is hard like a rock!
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
Year: 2021 Make: Acura Model: RDX Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 57,499 Plate: (A50324)
Year: 2021 Make...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2018 CATERPILLAR 249D SKID STEER (A51242)
2018 CATERPILLAR...
