daman1
Gold Member
Yes there does most think oil is oil grease is grease but that's farthest from the truth.daman1 there seems to be a lot of confusion (perhaps by design) on most fluids.
I know Traveller's Premium UTF states Meets OEM specs so maybe it is made by Shell as on was told. Warren may even make some of Shells products as far as I know.
The older thread on this subject is http://www.tractorbynet.com/forums/oil-fuel-lubricants/134738-tsc-travellers-hydraulic-fluid.html
no if you look at the pale of Trav prem UTF it states "recommended for" not "meets spec" and the renew states "meets specification" like i stated in my above post, there is a difference because the specs differ slightly, weather it's additives or level of friction modifiers for wet break applications or a GL rating for rear end use,they'll both work but one will be better then the other if you want to get technical.
no WPP,warren performace products dont make any of shells (SOPUS)Shell Oil Products U.S. lubracants
i agree bp fick,just wanted to let the OP know since he did ask.
