Pin on vs. Q/A Survey for FEL
   / Pin on vs. Q/A Survey for FEL #21
Every time I change between my bucket, pallet forks and front quick hitch in a single afternoon, and then back to nothing for mowing, I look up and thank heaven (or at least John Deere) for my quick attach loader.
   / Pin on vs. Q/A Survey for FEL #22
Deere QA here. I only have bucket and pallet forks now, but it's a simple/fast change from one to the other.
   / Pin on vs. Q/A Survey for FEL #23
Kioti CK20S - converted from pin-on to SSQA.
- It was expensive (~$650) to buy the loader adapter and convert my bucket, but I had it done when I bought forks. I did recover some money as I found a snowplow on craigslist which had already been converted to SSQA for just $300 which wouldn't have been an option without the SSQA conversion.
- It works great, changing attachments shouldn't taker more than a minute and doesn't require a grease gun. If I had bought pin-on forks I know that I wouldn't have switched back and forth between bucket & forks as nearly as often as I do. That's what pushed me to convert, as I knew the forks I was about to buy wouldn't have gotten nearly as much use if I was going to dread swapping attachments every time.
- The loss of curl force is noticable. It is what it is.
- I'd do it again!
   / Pin on vs. Q/A Survey for FEL #24
I also switched from a pin on to a ssqa. A tad expensive, but worth every penny. I would never get another FEL or tractor without SSQA. Like others have said it's a huge time saver, but more then that it cuts way down on the cursing, so I don't need to pack a lunch when I go to confession. :D
Wedge
   / Pin on vs. Q/A Survey for FEL #25
I can not believe you guys take off your loaders. I have had my current tractor for 7 years and the loader has been off once for one afternoon then right back on. I just use it way too much. I think its like my right hand.
Chris
   / Pin on vs. Q/A Survey for FEL #26
1st tractor - pin-on
2nd tractor - QA
Didn't realize what I was missing until I bought tractor #2.
QA from now on!!
   / Pin on vs. Q/A Survey for FEL #27
I have pin on. Undecided if I'd be willing to give up some performance for QA. Right now, couldn't justify the expense anyway; no more than I'd use it. I do have 3PH forks though.
   / Pin on vs. Q/A Survey for FEL #28
I have the Q/A on the FEL of my NH TN55. I wanted Q/A and I'm not sure whether I could have gone with pins. I seem to recall the dealer saying he wouldn't sell that size FEL without Q/A. I'm more that happy with the Q/A.
Steve
   / Pin on vs. Q/A Survey for FEL #29
Chris
Chris,
I don't take off my loader -- but I don't carry around the FEL bucket unless I need it.
   / Pin on vs. Q/A Survey for FEL #30
I have the Q/A on both my tractors. On previous tractors that I have owned I did not. Now, on a utility sized tractor, I would not want to be without the Q/A.
Having a removable loader is handy for 3 point work in tight areas such as narrow winding trails through the woods. Amazing how much more maneuverable the tractor is with out the loader.
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2002 Freightliner FL70 Elgin Street Sweeper Truck (A51692)
2002 Freightliner...
2020 CATERPILLAR 120 MOTOR GRADER (A51246)
2020 CATERPILLAR...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52576)
2023 TAKE 3...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
