New,Need help deciding on tractor.
   / New,Need help deciding on tractor. #11
have you checked with Fredricks in No. Al ??
   / New,Need help deciding on tractor. #12
fencepost, you will be really lucky to find a tractor with a FEL at a dealer for $6,000 or under. Have you looked through your local Craigslist ads?
If you can up that to $8,000 you can find some really good domestic machines (kubota, Deere) in that price range now that are newer (10 years young).
kenmac already mentioned the biggest Yanmar importer in the country (I would presume) but I am doubtful you can walk away under 6,000 there either.
Good Luck and don't rush into buying.
Yea I'm looking local and am not in a big hurry I just found those I mentioned and didn't know much about them. Still looking.
   / New,Need help deciding on tractor. #14
Check out Atlanta craiglist #1752563133 tks
   / New,Need help deciding on tractor. #15
Talk to Steve at Spalding Tractors.We bought a refurbished ym2500 with a Bush Hog but no loader for right at what your budget is.Imo it will fit your needs well.I injoy using it.
Hey Steve While I was replying guess who just called Father John I need to help him get his POS. lawn mower going Again. :laughing:
Carey
   / New,Need help deciding on tractor. #16
I think you should go for the Yanmar. Although I dont have the YM2000, my 169D (1401D) is a great tractor. It has always got the job done (even without the FEL) and it can run for hours on end with one tank of diesel.
Can a FEL be added to the Yanmar 2000? I also think it might be a reconed unit it has low hours. I've read parts are a problem. I really don't want somthing else to work on. Here latly everything I have has some kind of problem.
   / New,Need help deciding on tractor. #18
yes a FEL can be added to the YM2000, however it is a 2wd tractor and doesn't have power steering so it will be rough on the steering box with a really heavy load.
Parts for the YM2000 are not an issue, ,may be the easiest model to get parts for, what you have probably read is that parts for VN recons are hard to get? not exactly, the problem is a lot of times the VN machines have mixed parts from several different model tractors making it hard to know/find what part was used.
I can tell you adding a FEL after a purchase will cost you $3000-$3500 for an installed loader, its cheaper to find a machine with one already installed...but not easier :eek:
   / New,Need help deciding on tractor. #19
an FEL can be added to anything. If you already have other concerns. Why would you even consider this tractor ??
I'm just staying open minded. I'm looking at everything. Even an old city backhole that has had the rear boom removed.
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
Case CX160C Hydraulic Excavator (A51691)
Case CX160C...
2016 KBAR 157595AL Pressure Washer Trailer (A51691)
2016 KBAR 157595AL...
