3 point hitch pins
   / 3 point hitch pins #1
frankp0202
i am looking to find the 1/2 inch dia. pins that go thru the attachment bars on the 3 pt hitch that have female instead of male threads to secure them to the attachment. Has anyone got any help
   / 3 point hitch pins #2
A picture would help. I'm not following the question. 1/2" diam pins with female threads?
   / 3 point hitch pins #3
I'm pretty sure he's asking about the pins on the implement that engage the tractor's draft (lower) links.
I've never seen them with female threads, but I can't say I've ever looked for them either.
frankp0202 could check out Tractor Supply or contact the implement manufacturer.
   / 3 point hitch pins #4
Threads? Im missing something here?
   / 3 point hitch pins #5
Not quite sure of your use for them, but check the link below to see if this is similiar to what you're looking for.
McMaster-Carr
   / 3 point hitch pins #6
Could you let us in on what it is your trying to do?
Army Grunt
   / 3 point hitch pins #7
I'm not sure what the question is either.
I was going to respond last night but I didn't want to be the first to admit that I didn't know what "female threads" are.:laughing:
I assume he is looking for pins that go on an attachment.??....Should be easy enough to find.??....No.??
   / 3 point hitch pins #8
Just consider male threads as threads you see on a bolt & female threads as those where the bolt screws in. Male = external threads ; Female = internal threads
   / 3 point hitch pins #9
I'd think a nut has female threads. Like male threads are made with a die, and female threads with a tap.
Maybe OP Frankp0202 will enlighten us all. Seems we learn something new everyday here. :)
   / 3 point hitch pins #10
Ooohh. I get it.
Now, I wonder why Frank needs female threads.??
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2013 BRENNER TANK 10,500 GAL (A53843)
2013 BRENNER TANK...
Duetz Power Unit (A50120)
Duetz Power Unit...
