3 point hitch pins
   / 3 point hitch pins #1
frankp0202
i am looking to find the 1/2 inch dia. pins that go thru the attachment bars on the 3 pt hitch that have female instead of male threads to secure them to the attachment. Has anyone got any help
   / 3 point hitch pins #2
A picture would help. I'm not following the question. 1/2" diam pins with female threads?
   / 3 point hitch pins #3
I'm pretty sure he's asking about the pins on the implement that engage the tractor's draft (lower) links.
I've never seen them with female threads, but I can't say I've ever looked for them either.
frankp0202 could check out Tractor Supply or contact the implement manufacturer.
   / 3 point hitch pins #4
Threads? Im missing something here?
   / 3 point hitch pins #5
Not quite sure of your use for them, but check the link below to see if this is similiar to what you're looking for.
McMaster-Carr
   / 3 point hitch pins #6
Could you let us in on what it is your trying to do?
Army Grunt
   / 3 point hitch pins #7
I'm not sure what the question is either.
I was going to respond last night but I didn't want to be the first to admit that I didn't know what "female threads" are.:laughing:
I assume he is looking for pins that go on an attachment.??....Should be easy enough to find.??....No.??
   / 3 point hitch pins #8
Just consider male threads as threads you see on a bolt & female threads as those where the bolt screws in. Male = external threads ; Female = internal threads
   / 3 point hitch pins #9
I'd think a nut has female threads. Like male threads are made with a die, and female threads with a tap.
Maybe OP Frankp0202 will enlighten us all. Seems we learn something new everyday here. :)
   / 3 point hitch pins #10
Ooohh. I get it.
Now, I wonder why Frank needs female threads.??
UNUSED 16" AUGER (A51248)
UNUSED 16" AUGER...
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
2018 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 130...
2013 AUDI A4 20T SEDAN (A51247)
2013 AUDI A4 20T...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
UNUSED CFG QUICK ATTACH HYD HAMMER (A51248)
UNUSED CFG QUICK...
