hydrostatic heat and whine
   / hydrostatic heat and whine #21
My 2003 BX2200 does the same thing. I found that if I spray the linkage rod/spring with carb cleaner and then oil lightly with mineral oil, it works better for a while.
   / hydrostatic heat and whine #22
Thanks I will give that a try.
   / hydrostatic heat and whine #23
Couple of added comments to Rick480:
1. It's normal for the hydraulic fluid to get pretty darn hot during regular operation... 150-180 degrees off the top of my head. If you have access to one of those infrared thermometers, maybe you can get a better sense of just how hot it is on your machine. Over 200 is definitely not right.
2. BX's want to be run at wide open throttle, or nearly so, for sufficient hydraulic flow. If you are running at lower rpm, it will whine more and get hotter, as mentioned. Kind of at odds with going easy during break-in, but that's the way they are designed. I backed off the rpms some and used low range mostly when mine was new, and didn't use it for mowing a lot until it had racked up some hours.
   / hydrostatic heat and whine #24
In general, hydraulic fluids should run 80-100F above ambient temperature.
Mine is probably fine then, I would say in the 150-170 degree range after a hour or so of mowing, thanks for all the replies, makes me feel a lot better.
   / hydrostatic heat and whine #26
Since this post came out my buddy down the road stopped to see my new 3030, while looking at it he asked me if the trans. & rear end got hot during use like his 2920,(trans. fluid was full) I guess that is something I never thought about as I have only had it a few weeks, so after mowing about 1 hour Sunday (80 deg)I took a temp gun that I use for my RC trucks and checked it, the temp. gun showed 171.5 deg. I would have to say the heat is normal as compared to a automatic trans. in your vehicle, it's a pump circulating fluid to move a heavy object, as for the whine I'm going to try SUDT at my 50hr. service to see if it helps with that, this is my first hydro so all of this is new to me but I really like the tractor.
   / hydrostatic heat and whine #27
Good info.
The HST's pump section relies on air being moved by the fan for cooling it. It only stands to reason that the faster that fan is spinning, the more air it'll move over the HST where it's needed.
Lugging these little diesels is much worse on them than running them all day long at pto rpm.
Theres been a few folks that have posted pics from their heat guns showing cold then hot operation of their HST's and when warmed up to it's operating temps, the HST averaged 80 to 100 degrees hotter than the current ambient air temperature. In the case the air cooled HST of the BX, the higher boil point of SUDT is a plus.
FYI, Theres an additional wire connection under the BX's seat and on the older BX's it would lite another "mystery" warning lamp on the instrument cluster. It's been speculated that this was an HST overheat warning lamp for Kubota markets other than the N. American market but no one has verifed this. It's also unclear when this warning lamp was removed on the newer BX's. It was discovered when some enterprising individuals were looking for additional electrical power for rear lights etc. Seems when that particular lead was grounded is when it would illuminate the "mystery" dash lamp. If one were to try this on their BX be advised that grounding the wrong lead will blow your 20 amp fuse and you'll loose the ability to shut your engine down via the key switch :D
Dave
Checked the fluid temperature tonight after about a hour of mowing. 174 degrees in 82 degree ambient, guess that is about as expected so I will stop worrying. Thanks to everyone for their advice.
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
2000 KOMATSU VALMET 860.4 FORWARDER (A51222)
2000 KOMATSU...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
