Couple of added comments to Rick480:
1. It's normal for the hydraulic fluid to get pretty darn hot during regular operation... 150-180 degrees off the top of my head. If you have access to one of those infrared thermometers, maybe you can get a better sense of just how hot it is on your machine. Over 200 is definitely not right.
2. BX's want to be run at wide open throttle, or nearly so, for sufficient hydraulic flow. If you are running at lower rpm, it will whine more and get hotter, as mentioned. Kind of at odds with going easy during break-in, but that's the way they are designed. I backed off the rpms some and used low range mostly when mine was new, and didn't use it for mowing a lot until it had racked up some hours.
