Oil & Fuel Additivies to the oil
   / Additivies to the oil #1
rmully
Gold Member
North Carolina
YM 2020
When I changed the oil on this YM2020 it looked very black almost as if it was never changed in the 500 hours on it. I am thinking of changing it again in about 5-10 hours use. Should I add an oil treatment? and if so what would be the right choices. I used Rotella T 15-40
   / Additivies to the oil #2
I wouldn't. Your new oil is busy right now spiffing everything clean and suspending it or trapping it in your filter. If the filter you took off is recognizable and a typical, American brand name filter, chances are it got changed at some point.
If you new oil goes black prematurely, say 40 hours, then consider a second change. You will be good to go. I always felt most cleansing agents were too risky for the gaskets and seals. YMMV.
   / Additivies to the oil #3
I'm with BP and K7LN with respect to additives to modern day oils. The only time I add anything is when a service bulletin comes out from the engine or transmission manufacturer advising a special additive.
Jim
Thanks guys !! It had the original Capa filter on it so was not sure if just the oil change and filter were going to be enough. The hydraulic filter was also a Capa but that fluid was very clear.
   / Additivies to the oil #5
Change the oil when it begins to turn black, don't worry about the hours. There is nothing an additive can do for you. The "black" in the oil is carbon, which is dust. I don't like my oil full of dust.
   / Additivies to the oil #6
Norm,
That is exactly what I had to do to an FX335-D.
The oil was black after 2 hours of running, so I ran some napa engine wash in the oil for 10 minutes (at idle) speed, let it drain overnight, then changed the oil & filter.
Now the oil is clean for many hours before it even starts to change color.
Shell rotella synthetic... love the stuff!
   / Additivies to the oil #7
Norm,
once i ran some engine cleaner in a petrol engine the had about 300k on the odometer, it was quite gunky as they must have run cheap oil in it for a long period of time (was a courier vehicle) but the motor was quiet and smooth,ran like a dream until i used a cleaner. it knocked and rattled its head of after that. i ran some additives to quieten it down and traded it in.......... cleaners......... never again.
   / Additivies to the oil #8
So sludge was the only thing keeping it from knocking and rattling.
   / Additivies to the oil #9
THE SLUDGE REPORT
Im sorry to hear that it didn't work for you, I have washed many engines since then, and have never had a problem yet.
I think the trick is to just let the engine run at an idle, DO NOT rev them up during the wash process, that's what I was told to do, and just for 10 minutes.
   / Additivies to the oil #10
Maybe it starved it for oil, in Neat's case. I have heard of cleaning very sludged engines and the crap breaking loose and stopping up the oil pump pickup screen. Again just hear say no experience
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
KUBOTA M7-132 (A53084)
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
