Help me convert my chipper to 3pt
   / Help me convert my chipper to 3pt #1
arrabil
Winterstown, PA
JD 4200 & X475
So I'd like to convert my 10HP chipper to 3pt mount and either PTO or hydraulic power. Welding up the 3pt mounts is the easy part. I'm not quite sure what to do with the drive mechanism.
Its a Tecumseh HM100 engine. The tech guide says its 3400rpm. The parts guide shows the engine is directly connected to the chipper blade.
My tractor has 20 PTO HP and 7.3gpm hydraulic flow at the Power Beyond ports.
If I go PTO, what do I do to raise the 540 PTO rpms to 3400 and where do I get a PTO driveshaft yoke for the drive mechanism? Do I need a PTO gearbox? Or a pulley setup? I can't figure out where to start here.
If I go hydraulic, I'm looking at this motor as it seems to (more or less) match the specs I have and need (there is also a 0.75 cu-in motor but its a little less than I need). I'll need a pulley setup to double the motor rpm from the rated 1800. I get the feeling this motor isn't going to be powerful enough and that I will need to drop the whole idea of hydraulic power.
Any help and experience would be appreciated!!! Thanks!
[And please, I don't need the reasons why it would be better to keep it the way it is or why I should buy an already made one. I know what I want to do and why. Just need help figuring it out.]
   / Help me convert my chipper to 3pt #2
Hydraulic really isn't a viable option for you - it would take a huge amount of both flow and power to run a chipper from hydraulics.
So, a PTO drive with gearbox that provides 6.2:1 (or is it 1:6.2) gearing. If you can incorporate some type of flywheel, it will allow the chipper to use stored energy to get thru the rougher chipping situations. A flywheel from an old baler would be good - just remember to shield it from inquiring body parts. Oh - and you need to make sure that the chipper still turns in the correct direction after the gearbox.
You also need to consider the driveline physical pathway.
Good luck!
Mike
By "driveline physical pathway" I take it you mean where the PTO shaft goes? And safely? That won't be a problem; with the engine gone the platform has lots of room all facing the right direction.
I was looking at parts breakdowns of the Woods chipper yesterday. They use a double pulley system to up the rpms and they only chip at 2400. I was thinking I could get away with a 12" and 2" pulley if needed.
So the real question is: where does one find PTO gearboxes? They make these things in all different sizes?
   / Help me convert my chipper to 3pt #4
If you're looking for used, I'd use a gearbox from a mower or similar implement. If new, go to a dealer and inquire.
Mike
   / Help me convert my chipper to 3pt #5
A good used box off a shredder shoud be more than enough for a 10 HP chipper.
I looked at doing this with our Craftsman chipper after a can of blended fuel fouled the carb when stored over the winter (didn't realize it was bleded).
My plan was to mount the chipper to a drawbar ($25), install a pair of pillow blocks where the engine *was*, to connect the PTO shaft to and find a pulley that was about 5 times the diameter of that on the engine that I removed. I was going to mount the PTO coupler to one side (recoil side) of the chipper and the pulley on the drive side which allowed me to re-use the belt guard.
In this configuration, there was no need for a PTO gearbox.
   / Help me convert my chipper to 3pt #6
Doesn't look like you'll need a gear box if the chipper's knives/flywheel are perpendicular to the driveshaft. This would depend on how the original motor was situated on the chipper frame. Since you're doing a total rebuild, you can set the chipper knives/flywheel however you want (on the frame).
By keeping the knives/flywheel perpendicular to the drive shaft (substitute PTO shaft), looks like all you'll need would be pulleys of the correct size to increase the knives/flywheel speed to what you want (that is, from 540 RPM to 2400?). Then, of course, a belt that can withstand that speed and inertia as well as some kind of tensioner to keep that belt tight (but not too tight). If my logic is correct, you won't need a gear box unless you need to change the drive shaft (PTO shaft) input direction.
I've attached the parts breakdown from the Woods 5000 chipper/shredder. As you can see, there is no gear box...just two pulleys (and bearings/pillowboxes). IIRC, the flywheel (which holds the chipper knives as well as the shredder assembly) weighs around 125 to 150 lbs. If you add a flywheel, you want to ensure the entire rotating assembly is balanced.
Of course, the next question is, can your current chipper handle a doubling of input horsepower? I have no idea about that...
  • Pages from Woods 5000 chipper.pdf
   / Help me convert my chipper to 3pt #7
IMO, I would think that 2" pulleys would not have enough surface area to properly transmit the power to the chipper shaft, unless you went with a 4 pulley system, up that to 3" and I think you would be able to get by with 2 "B" belts,
My first thought was sprockets, but to protect the tractor from shock loads or jamming you much better off with the belts as they will give and slip and protect the PTO transmission, a slip clutch may be desired as well,
but belts and that Idler tension pulley would be the way to go, IMO
   / Help me convert my chipper to 3pt #8
I've actually looked at doing this in the past until I found a used one. Look at a Mighty Mac by Mackissick chipper. They had motor run models and PTO models (what I bought). The PTO model is identical to the motor run model except its run off the tractor. PTO shaft, 2 pillow block bearings, large 2 belt pulley on bottom and small 2 belt pulley on input shaft.
What do you guys think of running it at lower RPM? Its rated at 3400rpm but will it really chip worse at 2400rpm?
And while I definitely don't want to stall the tractor, why isn't it stall protected the way it sits? In fact I stalled it on some vines a couple weeks ago.
Is a PTO slip clutch enough protection against stalling the tractor? Reason I ask is that I'd really like to investigate using gears instead of belts. It would make it so much easier to build.
As to whether or not it can handle double the input HP? Its a pretty strong design from what I can tell. As long as I don't try to stall it out all the time I would think it wouldn't know any different. I was thinking if I gear it 6:1 and then run it at a lower speed that would be better too.
   / Help me convert my chipper to 3pt #10
Personally, I think it'll clog up at anything less then 2400 RPM, but that's nothing more then an opinion. You could always change the gear ratios to increase speeds if it turns out you need faster movement through the chipper.
And, I don't think gears would offer the protection that belts would. If it does clog, the belts would likely slip, gears won't. Odds are, something will break.
What is the capacity of the gas powered chipper? 3 or 4 inches? Do you expect to increase that capacity by going to a PTO driven chipper?
As far as the slip clutch...definitely. You'll have to experiment to figure out how much slippage you want (to protect both the tractor and chipper).
2010 Pontiac G6 Sedan (A48082)
2010 Pontiac G6...
Hotpoint DBL1550BALAD Dryer (A50860)
Hotpoint...
Bundle of 40 Gauge Pipe (A50860)
Bundle of 40 Gauge...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2008 Ford F-250 4x4 Reading Service Truck with Liftgate (A48081)
2008 Ford F-250...
Informational Lot - Shipping (A51039)
Informational Lot...
