Blocking the clutch on a 4400
   / Blocking the clutch on a 4400 #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Hope one of you 4200, 4300 or 4400 owners with a gear transmission can help me here...
My old 790 had a tab (on the floor plate) I could clamp the clutch pedal to when the tractor sat for an extended period.
Haven't found anything like this on the 4400 (yet). Is there something similar, or am I going to need a block of wood (or something similar)?
   / Blocking the clutch on a 4400 #2
There should be no need to block pedal down on 4400. It has a wet clutch where the 790 had a dry clutch. The dry clutches tended to absorb moisture and rust to the flywheel when not used for extended periods. For that reason deere did not provide a way to hold pedal down on 4000 series.
Good point!
I'd forgotten about this being a wet clutch.
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
Freightliner Tender Truck (A55301)
Freightliner...
2016 Chevrolet Cruze Limited Sedan (A53424)
2016 Chevrolet...
