Blocking the clutch on a 4400
   / Blocking the clutch on a 4400 #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Hope one of you 4200, 4300 or 4400 owners with a gear transmission can help me here...
My old 790 had a tab (on the floor plate) I could clamp the clutch pedal to when the tractor sat for an extended period.
Haven't found anything like this on the 4400 (yet). Is there something similar, or am I going to need a block of wood (or something similar)?
   / Blocking the clutch on a 4400 #2
There should be no need to block pedal down on 4400. It has a wet clutch where the 790 had a dry clutch. The dry clutches tended to absorb moisture and rust to the flywheel when not used for extended periods. For that reason deere did not provide a way to hold pedal down on 4000 series.
Good point!
I'd forgotten about this being a wet clutch.
2017 KOMATSU PC290LC-11 EXCAVATOR (A52706)
2017 KOMATSU...
2023 Load Trailer (A55787)
2023 Load Trailer...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
UNUSED KIVEL TRAILER MOVER ATTACHMENT (A54757)
UNUSED KIVEL...
DOWNING MANUFACTURING BITUMINOUS APPLICATOR (A51406)
DOWNING...
