Continuous 12 volts
   / Continuous 12 volts #1
BeeFarmer
S.E. Ohio
TC 33D
I have a TC 33DX and without running a wire directly to the battery or engine area is there a 12 volt source near the rear that is on all the time?
thanks
   / Continuous 12 volts #2
I didn't see a response yet for your model, but my TC40D has a single connector in the bundle running to the right rear turn indicator that fits your requirements. You might look there.
Thanks! Are you talking the right rear flasher? Thanks again.
Checked it out, doesn't appear to be the same with the 33. I have the flashers, tail light, and spot light only. Any one else have an idea? Thanks
   / Continuous 12 volts #5
It would only take 5 min to run a single hot wire from the battery. Put in a fused link and ground it at the location you will use it at. What are you going to hook-up to it? Why do you want to use an existing one?
Hooking up the switch side of a radio. Otherwise it looses it's memory
2013 Haulotte 4527A (A57148)
2013 Haulotte...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
Schuler 125BF Feed Wagon (A59814)
Schuler 125BF Feed...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
