HydrauLink- a self-contained air over hydraulic top link
   / HydrauLink- a self-contained air over hydraulic top link #141
OK, my question is: Why is the travel so short? I have never seen a cat1 with less than 6" travel, and even that is limiting. 8+ is much more useful.
larry
HydrauLink has a 6" stroke plus an additional 4 3/8" screw end for needed adjustments for a total of 10+ inches. Did I answer your question?
Yes, you did. I see that the 4th bullet in your specs section needs some clarification. It has been misunderstood several times on the thread. I wish you had noted that and corrected it at the first reference to 4" travel from posters that had read your ad. 29" max is not a bad length. Presumeably you will offer an extended mechanical adjuster for those that need a bit longer, but dont need it ever as short as 19"?
larry
   / HydrauLink- a self-contained air over hydraulic top link #142
Alright...I've read all the questions and responses...the gentleman seems to be very open to discussion. However, I think the price point is too high and the device's advantages are negligible. I don't see it as a "gap filler" type of product as in "somewhere between a HTL and a screw jack". I don't want to cost him any business by suggesting this, but, I made my own easily adjustable mechanical screw jack years ago by taking a cheap, 1/2" drive, long handled ratchet and fitting the inner workings around (with welds) the nut on the screw jack...it works great for my use, requires no tools, provides plenty of leverage for my arthritic arms and only requires an occaisional shot of WD-40 for maintenance. Total cost on an existing mechanical top link? About $20 for the ratchet at Northern Tool and 10" of MIG wire. Mine doesn't do the "shock absorbing" action, but, for my uses, I see that function as more of a detriment than an advantage. Looking back on the adaptation I made, I can see where the same principle would work with a ratcheting load binder and would probably be better...if I ever need to make another, that's probably the route I'll take.
Check out our new video. It should answer a number of people's questions regarding adjusting HydrauLink, and the implements it is attached to. Check out the Installation and the Adjustments videos.
You'll get a good look at just how hard HydrauLink works and how easy it is to work with.
Demonstration video
And Happy Fathers Day.
larry
Thanks for pointing out the bullet...I've made the changes to it. As far as your question goes, I'll look into it and get back to you.
Thanks HydruaLink again for your response. I'm contemplating going with an active hydraulic top and sidelink but am on the fence and definitely don't wish to buy both systems. This typically means I'll be paralyzed by indecision and likely be with the screw link for awhile.
Just so you know, we've posted a new video on our site to address some of the adjustment questions. Hope this helps.
http://hydraulink.net/video.html
Thanks for your input. There are a number of 'home-made' concepts out in the wild and yours sounds great. However, HydrauLink's self-adjusting, shock-absorbing, easy installation and adaptability make it a powerful option for many people. It offers features that no other top link available can offer.
   / HydrauLink- a self-contained air over hydraulic top link #147
Mustang do you any pictures sounds interesting
   / HydrauLink- a self-contained air over hydraulic top link #148
My daughter took our camera with her on vacation...I'll post some pic.'s when she gets back.
   / HydrauLink- a self-contained air over hydraulic top link #149
Funny Ive seen the opposite. I see good dialog going on here. I give allot of credit to the company's rep here for answering questions, The company has a goo insight into people needs, and good feedback form people who haven't already bought one.I was impressed with the solenoid suggestion. I think it great they have this feedback.
i havent seen anything to harsh to me, at least the company rep seems to take all well.I personally have a hyd myself but still like the question and answer part. Gives me a good insight as to what it and how it operates.
Bottom line is its not for everyone, and im sure its just right application for another...
I also agree with bedlam on this point...this is a great discussion and this is precisely why I come here to read others options, positive and negative. I can take that and make up my own mind. The vendor has offered up a new product, he's gotten some good feedback on the way he's marketing it, not necessarily whether the product is good or bad. Now let's see what he does with it. My hope is that the vendor will be just as tenacious describing WHAT he is selling as he is describing its its benefits.
   / HydrauLink- a self-contained air over hydraulic top link #150
Here's my opinion from what I've read so far. My thoughts come down to two key points:
* Good product design
* Poor marketing
Let's focus on marketing. Here's my free marketing advice. The market niche this product should be focusing on is all the subcompact and compact tractors out there with no rear hydraulics. The market price should be positioned between a standard top link and a hydraulic top link, more in the $100 range. Then HydrauLink should talk with compact tractor manufacturers about making their product an option at point of sale.
The full size tractor market is better served with a full hydraulic top cylinder or top-n-tilt.
Darrell
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
2002 Miller Trailblazer 301G Towable Welder Generator (A59228)
2002 Miller...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
Deere 35G (A53317)
Deere 35G (A53317)
2017 John Deere 1025R Tractor - 626 Engine Hours (A56436)
2017 John Deere...
