How many tractors have you owned?
   / How many tractors have you owned? #32
McCormick W4--Massey Harris Pony---Satoh 650g--Ford 1310--IH b275
Currently a Kub MX 5000
That makes 6
   / How many tractors have you owned? #34
Have you considered trying to have it welded before it breaks all the way?
I have. It would take some disassembly to do a proper cast iron weld with the pre and post heat recommended. It's on an outside radius portion of the casting, don't know if that makes a difference. Not sure if it could be done without removing the bellhousing completely. If the bellhousing has to come off the tractor to weld it, then it seems like a new one is the much better choice.
I read the failed welding attempt posts and have researched cast welding on-line to try and decide if that is a viable solution. Not being a welder, I don't have my own opinion. From what I have read, successful cast iron welding is not a given even when following all the recommended procedures.
I should get an eyeball opinion from a prof. welder.
Dave.
   / How many tractors have you owned? #35
Dave.
Sorry to here about the crack. I've known some people that acted like they t smoked crack, but have never seen a cracked bell housing on a tractor. Must be a dismal sight.
I would think that if you had it welded you would always worry about it. The price difference may not be worth the added aggravation.
Mark
   / How many tractors have you owned? #36
One ... owned for 4 days now!!
Kubota Grand L3940; HST; LA724 FEL; R4 tires :thumbsup:
   / How many tractors have you owned? #37
   / How many tractors have you owned? #39
Dave.
I have to agree with you that if you have to split the tractor and pull the bellhousing, you might as well just replace it. No sense paying money for something which may or may not work. I'm not a welder either. I was just thinking maybe there was an easier cheaper way. Doesn't sound like it. Too bad.:(
2006 YAMAHA RHINO 660 RTV (A58375)
2006 YAMAHA RHINO...
2012 Chevrolet Equinox (A57148)
2012 Chevrolet...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
(10) UNUSED SDLANCH 2.5CM X 3.5M RATCHET STRAPS (A58375)
(10) UNUSED...
TANK MANIFOLD (A58216)
2014 JLG 6042 TELESCOPIC FORKLIFT (A52709)
2014 JLG 6042...
