Center of gravity with FEL
   / Center of gravity with FEL #11
There are no absolutes. On some bigger tractors, the percentage of weight is so small as to be inconsequential on many slopes. Most farmers never remove their FEL in my area and much of it involves operating on slopes.
As Roy says, ballast can be substituted for a FEL, but I almost always wind up using my FEL when bush hogging to move a log out of the way or to haul a little rock going to or fro, so I prefer to keep a FEL on my L5030 most of the time. My BX2660 scares the snot out of me with a FEL on a slope and will almost always take it off unless going straight up. My son in law has my old BX2200 and mows a pretty steep yard and he has never taken the FEL off and doesn't even use rear ballast; don't know how he manages, but he does.
The most stable hill tractor I have is a Massey Ferguson 375 with no front ballast, turf tires on the back and Ag's on the front. It will go just about anywhere, well when it's running...
   / Center of gravity with FEL #12
A general statement like that with no explination does no one any good.
Tractor with bushhog going up a steep hill with no loader = RIP
Actually it does some good if it prevents somebody from being killed. Okay here's the explanation. If you use a tractor with a FEL on a steep slope the tractor may roll over and kill you.
The safest way to mow a steep hill is to use reverse so the front of the tractor can't flip over. That way no loader is needed.
   / Center of gravity with FEL #13
Sheep would work well also!:thumbsup:
   / Center of gravity with FEL #14
Correct! Sheep wont flip over either. ;)
   / Center of gravity with FEL #15
Going down steep hills the FEL usually works as a better brake than the wheel brakes.:thumbsup:
I learned that on a skidsteer.
   / Center of gravity with FEL #17
How do you Guys keep the Sheep and Cattle in the bucket?? ~S
   / Center of gravity with FEL #20
Thanks for the clarification! Here I was thinking Freezer Paper, and Ice! I'm "so" not with it! ~S
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
