turning with implements on the ground
   / turning with implements on the ground #1
MikeA57
N. Mississippi
Ford 1510
I was searching today for drawbars and stabilizers and I came across a series of web pages that explained using drawbars, 3 point hitches and implements safely. I started reading just to see if there were any tips I could pick up. On one of the pages, it mentioned that you shouldn't make a turn with an implement in or on the ground. I guess I could understand this if it was a disc, or tiller, harrow or something like that, but what about a finish mower or bushhog? That's the first time I've ever heard that but it doesn't seem to make a lot sense to me. Does that same thing go for mowers?
Here's a link to the webpage I saw that on:http://www.nstmop.psu.edu/tasksheets/5.3%20Using%203-Point%20Hitch%20Implements.pdf It's on the 3rd page, last point in the middle row.
Mike
   / turning with implements on the ground #2
Mike, part of the mowing with my bushog are 90 degree turns with the mower on the ground...Not sure what they mean by.....don't.
Don
   / turning with implements on the ground #3
That's for ground engaging implements. For floating or wheeled implements like cutters, it's not necessary. Be sure to have your sway chains/bars in place though or you could bend a lift arm.
The article also states to raise the implement during transport. How are you going to do that with a manure spreader or trailer?
   / turning with implements on the ground #4
When i cut with my LX4 Flail mower, I mow at 1 inch height, and that makes the skid shoes ride on the sod. if I turn when the skids are down on the ground, then it sometimes digs in and rips a bunch of sod out, and likely strains the whole mower, because its twisting it. I try to just lift it off the ground, so its only on the rear wheel, and it turns perfect.
   / turning with implements on the ground #5
Well,if you didn't turn when brush hogging you would run into something.
   / turning with implements on the ground #6
I'd guess they are not classed as implements on the 3ph, or ground-engaging. ;)
   / turning with implements on the ground #7
I turn all the time with my rotary cutter, I assumed that's why it had a swivel wheel on the back.
   / turning with implements on the ground #8
I think you can turn with some ground engaging implements if you use your head.
I don't know about a plow or disc or tiller. Although I have made turns with the tiller because I have some rows that are curved. A brush hog is OK, which has the swiveling wheel(s) made so you can turn. But then it's not really "ground engaging".
For sure, don't turn with a sub-soiler or box blade with scarifiers (rippers) down, engaged in the soil. This is because the rippers are a lot weaker taking side-ways force, like through a turn, and they will bend or break. Don't ask how I know this.:) Turning with the box blade full of dirt (rippers NOT down) is OK. I do that all the time.
Rob-
   / turning with implements on the ground #9
That's right but the article didn't differentiate implement attachment. Wasn't that was the whole point of this discussion? :confused:
   / turning with implements on the ground #10
Not to belabor the point, but the article had to do with 3 ph attachments (as I read it), so it did differentiate attachment.
205028 (A52706)
205028 (A52706)
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A53843)
HYDRAULIC THUMB...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
40' CONTAINER (A51244)
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
John Dozer JD650 (A51691)
John Dozer JD650...
