Egon
Epic Contributor
I would consider buying a washable filter because in the long run i would save money..
That sounds like a very good idea.:thumbsup:
If feasible install two in parallel so one is in use and the other is being cleaned.
I got sick of replacing those little filters so I started checking into larger units. What I came up with works very well for our house and was not all that expensive especailly when one considers the cost of cartridges........................ a pool filter. I use the sand type and have had awsome luck. The most I have to do is backflush every now and then. I do have an additional filter on the kitchen sink and refrig for drinking water.
Our well is 340 feet deep.. the pump is around 325 feet (it was raised up a while back after we installed a 'sand filter' on the pump).. its about 80 feet of casing and then rest is in granite.. they hit 3 different water sources (deepest was at 200 feet) and we get about 6 gallons a minute..
In our area wells run from 200 to about 700 feet deep..
We had the 'check valve/backflow valve' on the pump go out and stir up a lot of stuff (also reason for the sand filter since the pump was pulled).. Before the check valve went out there were no problems with the well for 3.5 yrs.. I only had to change the water filter about every 1.5 to 2 mths..
After those repairs we ran a lot of water and it cleared up after about 4 or 5 days - almost back to normal.. then we were gone on vacation for a week and came back to the muddy water again.. This is where we are now - trying to figure out why the water is still muddy..
Brian
Brian,
I haven't been on this thread in awhile so excuse me if I missed something but have you checked with your neighbors? How are their wells doing? Any mud or silt problems?
We're having a relatively dry summer here and the water table drops and then rises when we get a storm which can stir up wells. Also is any work being done in your area like a new housing project that might affect the wells.
Sounds to me like something else is going on.
Rob
