When did the 20 series change to 1 piece rims?
   / When did the 20 series change to 1 piece rims? #1
whitedogone
Gold Member
Central Illinois
JD 4120
Our '05 4120 has 2 piece rims. But I noticed that the new one xx20's have 1 piece rims. When did Deere change? And why would they do that?
   / When did the 20 series change to 1 piece rims? #2
I think the rim change was only with R4's. The R1's still have the 8 position, 2-piece rims.
One reason for the change-over might be - they're a PITA to take off and re-adjust for width. And if you aren't careful when you re-tighten the bolts (cross-hatch pattern) you can get an unbalanced rim that will constantly work loose and need to be re-tightened.
Most users with R4's don't worry about row-crops or orchard use, hay production, etc. so, changing the tire footprint is not a high priority.
AKfish
   / When did the 20 series change to 1 piece rims? #3
AKfish
Correct, and they are less money too
   / When did the 20 series change to 1 piece rims? #4
My dealer told me JD rolled the R4 solid rim change in on the 4X20 models sometime in 2009. So now you have only two choices with R4's -- either very narrow width around 71" or very wide width at around 90". The last I checked the Operators Manuals and sales literature had not yet been updated to reflect the change. When the dealer delivered my new 2010 4320 a few mos ago I was surprised with the new welded one piece wheels. I'm now looking at getting wheel spacers to get out to 78" or 79".
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A49461)
2016 Ford F-150...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
2013 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2013 MACK ELITE...
