What's this in my rear tires?
/ What's this in my rear tires? #1
F1520
Central NH
Ford 1520
A few months back I bought a used Ford 1520. In each of the rear tires, just to the inside of the center seam of the tire, is something that looks like a nail embedded up to the head with a rubber washer under it. (See pics) Does anyone know what these are? :confused:
Thanks!
/ What's this in my rear tires? #2
roofing nails? Used for tin roofs.
/ What's this in my rear tires? #3
that is a galvanized roofing nail. that type is used for attaching tin to barn roof. its long enough you will have problem when removed. most likely have slow leak now.
/ What's this in my rear tires? #4
As said roofing nail..99% sure you pull nail by morning almost if not flat...ask me how I know. ;)
Yeah, they do look like that. :laughing: But these look too perfect to be roofing nails that someone ran over. Could this be some way of loading tires?
/ What's this in my rear tires? #6
They do look like roofing nails for a tin roof. Is it possible that your tires are filled with foam. That they put the holes in the tires to vent the air out while filling?
Hm... roofing nails. One in each tire? In exactly the same place? (Just to the inside of the seam, centered between the ribs at the low point of the tread.) The tires haven't gone flat, and I haven't added air, in the few months I've had the tractor.
If these are nails, it seems like it would be easy enough to pull 'em and put in a Safety Seal plug.
Aha! Yeah, that's the kind of thing I was thinking. Hmm........ hadn't thought of foam. Maybe that's why the tires haven't gone flat!
Looks like we have a winner! :thumbsup: At the valve stem there is some residue that appears to be from urethane foam.
The roofing nail may be to plug the hole that allows air to escape while the foam expands and cures.
Guess I won't need to worry about the pressure in those rear tires. :D
Thanks to all!
Ed
/ What's this in my rear tires? #10
I was going to say those are the lead headed roof nails for securing a tin roof on like sheds (hones all use screws with the rubber grommets as they seal longer better).
Good call on the foam, would not have thought that at first, i think you have a winner. You could cut a chunk out of them and still be fine
/ What's this in my rear tires? #11
Well, ummmmm..... if there is no chance they go flat with foam in them why even bother to plug the holes up???
That's a good question. To keep out water? Just plain looks better? It seems like the foam would expand throughout the space between the tire and rim and maybe even come out the "breather" hole a little at the end of the process. Someone who knows more about foaming tires than I do is going to have to answer that one!
At least it would keep people from wondering why there are roofing nails with washers stuck in their tires. :D
/ What's this in my rear tires? #13
I have seen all terrain man lifts with what looks like the head of a 3/8" bolt in each tire. I asked they guy servicing one of them about the bolt heads, he said the tires were foam filled.
2019 GALYEAN...
2016 Dodge Grand Caravan SE Plus (A59231)
2016 Dodge Grand...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
CASE 610 Sprayer System 2000 Gallons (A61307)
CASE 610 Sprayer...
2007 Ford F-750 2,000 Gallon Water Truck (A60352)
2007 Ford F-750...
