My Cockshutt 40
   / My Cockshutt 40 #1
RRILEY
IN
John Deer 2520
I have finally found a good project to keep busy for years.
   / My Cockshutt 40 #2
Neato. The sheet metal on that 40 looks in good shape. That's my primary criterion for buying old iron--I suck at sheet metal work.
Have a ball.
Right now I'm restoring a 1951 Minneapolis Moline BF.
   / My Cockshutt 40
I got it home today. Now it's a foot taller. Was hard to see with all the weeds how much it sank in the ground.
Now I need a gallon of liquid wrench, I did get one brake working today and discovered it also has a parking brake.
This is going to be great. Unfortunately I have never done sheet metal work yet but do have friends that have Hot rods and old cars.
   / My Cockshutt 40 #4
That thing is gorgeous! Please keep us posted with Pic's as you restore. Even if it takes 5 years....
I would be trying to decide where to start. Maybe a bit of cleaning and tinkering around the engine to see what the status is. Put some oil down the spark plugs holes, compression test, see whats up, etc.
Do you have any knowledge of it's past? How long has it been since it ran? Was it running when parked? I'll shut up now.
   / My Cockshutt 40 #5
Are you planing on complete tear down..motor.tranny etc.
Tin looks good,finger cross for normal wear.
   / My Cockshutt 40
Yes I know the guy I bought it from and he said he just parked it and there it sat.
I went to a fourth of July party with the wife to watch fireworks and another friend is renting the old farmhouse and the owner also was there. I put a bug in his ear and saw him a week or so later and worked it into the conversation.
He said yes and said he wont give it away and was $200.00 more than I was going to start so I said I'll take it and we shook hands.
Now I have been pouring Liquid Wrench all over and got the right brake to work, not the left yet.
I want it to be original and found vintage tractor parts places and a cockshutt web page and that is very helpful.
Haven't told the wife yet because she didn't think I needed it.
Now its in the driveway with flat front tires and the are really sad shape. I will tell her "Look what the Tractor Fairy brought me" when she gets home.
"PRICELESS" I will post pics of the progress and I have no doubt I will need information in volumes,
The other friend that lives there said the owner absolutely did not want him to work on it or anything.
Thanks,
Bob
   / My Cockshutt 40
Sorry forgot to mention that yes I plan on a complete tear down for the engine , but the transmission work I have never done. I will replace seals for the PTO and such but to get into that scares the you know what out of me.
The tin has minor issues so I feel lucky and also have friends that restore old cars so maybe I can get help with that.
I have been pouring liquid wrench on the spark plugs to help and will wait about a week or so to try to remove them. I want to make sure the engine is not froze.
It's hard not to pick up some tools and see what is this going to do.
Bob
   / My Cockshutt 40 #8
Blow the dirt out around the plugs before you take them out if they are recessed. I wouldn't know where to start except to take a LOT of pic's from every angle and many closeups too.
   / My Cockshutt 40 #9
If your wifey totally erupts, you can blame it on me and I'll come take it off your hands...:D:D:D
   / My Cockshutt 40 #10
Personally, I wouldn't touch a thing. I think it's perfect as is.
   / My Cockshutt 40 #11
becarefull of the exhaust manifolds one these old oliver/cockshuts. they have a tendecy to get hairline cracks in them. my super77 and my 70 had cracks in the manifolds when we drug them out of the shed to get em going again. they had been sitting since the 80s along with a JD g 2banger.
   / My Cockshutt 40
The cats out of the bag, the wife got home this mourning. Of course it's "What are you going to do with that". She was not upset. I really did not think she would be either. I did get the spark plugs loose today. Now to find a socket large enough to try to turn it over, after I clean out the depression for the plugs.
I will have many pics to remember what went where to help put back together.
Bob
   / My Cockshutt 40 #13
Bob
Not to worry. If that Cockshutt 40 tranny is anything like the 3F/1R box on my 1951 MM BF, it's simple as can be--a handful of gears, 4 forks and 3 rails.
The most difficult part is getting the all the forks to engage their proper gears simultanously as you button up the tranny. It takes a little maneuvering, but it's really easy to do.
   / My Cockshutt 40
Thanks flusher. That makes me feel better about the rear end part. I am going to start with the tires and rims because the fronts are falling off the rims and the backs are loaded and bulging ready to bust. the left rear rim is so badly rusted I don't think I can salvage it. This is a learning curve for me.
I thought I would start with the front to rear after I pull the engine and replace bearings steering bearings and radiator , and did I forget rebuild starter and generator, and lets see, what else I can find.
I have noticed on the starter and generator there is a little spring like cap so I can put oil in them. But now I think about it I will tighten up the spark plugs and get some de-greaser and give her a good cleaning. It looks like the valve cover gasket has seen better days and the dip stick looks about like grease.
I'm happy.
Bob
   / My Cockshutt 40 #15
congrats on the tractor!:thumbsup: that will definitely be a lot of fun to fix up.
   / My Cockshutt 40 #16
I'm happy.
Bob
Don't forget to rebuild the water pump on your 40.
I'm having trouble getting the pump on my 1951 MM BF disassembled (don't want to damage the cast housing since I haven't been able to find a replacement pump with housing--only have the rebuild kit for the innards). The bearing on that BF pump is siezed and is really stuck in the housing. I may have to send the pump out to a rebuilder to get it disassembled and refurbished.
   / My Cockshutt 40 #17
View attachment 171821 View attachment 171822
I noticed that I made a couple of errors--it's 4F/1R and there are 3 forks, not 4 in that BF tranny.
   / My Cockshutt 40
The tranny is 6 forward and 2 reverse. I have found on Steiner tractor parts I can get a new water pump and other necessities like distributor caps and such so that will help.
   / My Cockshutt 40
Forgot to mention there is a hydraulic pump on the left side that will have to be addressed when I tear the engine apart. This could get interesting and I am glad I have a friend that does this sort of thing.
I will take pics tomorrow and post this pump. what is really cool is the valve switch connected to the operators station with a bent rod connected to a threaded rod through the control valve. That part has some serious rust. The pics will show a lot.
I'll get my shoes back on and will be back before dark,
Bob
   / My Cockshutt 40
Here are some pics,
Kuhn FC400RG (A60462)
5' MOWER (A52706)
5' MOWER (A52706)
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
2026 tilt trailer (A56859)
2026 tilt trailer...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
