pre made hydraulic hoses
   / pre made hydraulic hoses #1
unitedhose
Advertiser
toronto, canada, buffalo USA
Does anybody stock premade hydraulic hose assemblies?
If so what is the common size of hose you stock 3/8 inch hoses or ス hoses and
What are the most common lengths you stock?
   / pre made hydraulic hoses #2
TSC stocks hose.. 1/4, 3/8 and 1/2" male pipe to male pipe.. 3-4-5-6' lengths.
soundguy
   / pre made hydraulic hoses #3
just take the one you need to carquest or napa and they will make it up for you in about 10 minutes and it will be right-not expensive either compared to the local tractor dealer-just replaced 5 on my kubota loader-so savings were good-there hose was rated higher then Kbota's----------hope this helps
   / pre made hydraulic hoses #4
it looks like he is an advertiser, hose maker maybee.. and he is trying to get an idea of who his competition is and what they do.
soundguy
   / pre made hydraulic hoses #5
I think he is trying to find a consumer market. But like it has been stated before, why stock a bunch of hoses not knowing what you may need, if you can go to your local Napa store and have it made. Sure that single hose might be more expensive, but still cheaper than stocking a bunch of hoses you won't need. The only way I think this can be justified is if you have a machine or machines that has the same hose fail on a regular basis, like certain implement hoses.
I wish I could be more help to him, but I have had my own Weatherhead machine, hose, and fittings, for the last 10 years and buy them at wholesale. So I can custom make hoses with 2-wire hose for slightly more than they sell their hoses for.
Brian
   / pre made hydraulic hoses #6
lately my hose insurance has just been to keep a spare long one that would fit the longest connection or the short connections with the excess routed out of the way.
not a perfect fit.. but with a couple wrenches you can change it inthe field and not quit working as long as you don't loose more oil than you have with you and your spare hose.. :)
soundguy
   / pre made hydraulic hoses #7
the way I read it is he is looking to find out the most common size in diameter? perhaps to buy it by the roll and cut to length himself.... what I've purchased for my cut is SAE-1/2 although not sure if this is a standard size for most hydraulics.....
   / pre made hydraulic hoses #8
the higher the volume, the larger diameter you need. I'd wager 3/8 hose is pretty common on soft line / non motor applications untill you get up to high volume cyls / larger equipment.
soundguy
   / pre made hydraulic hoses #9
soundguy
The TSC near me makes up whatever you want, while you wait. Just started this year, I think.
   / pre made hydraulic hoses #10
wow... the staffers at my local store are doing good if they can find an item hangin on the wall .. I'd never trust a hose they made...
soundguy
CASE 6591 T/A PORTABLE POWER UNIT (A51243)
CASE 6591 T/A...
2007 Generac QT06030AVAN 60kVA Gasoline Generator (A50322)
2007 Generac...
2016 CATERPILLAR 262D WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
UNUSED AGT ATK-B1000 2 POST HYD CAR LIFT (A51244)
UNUSED AGT...
2023 JOHN DEERE 317G SKID STEER (A51242)
2023 JOHN DEERE...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
